Hue Lights - Free Philips Hue Plugin
Thu May 18, 2017 2:57 am
nsheldon offline
Re: Hue Lights - Free Philips Hue Plugin
Public Beta 1.6.0 Test Request
Hello everyone. I'm releasing a public beta version of the Hue Lights plugin (version 1.6.0 beta 2) for anyone who'd like to volunteer to test it out before the final version is released. Here are the changes from the current release version 1.5.3.
Download Hue Lights 1.6.0b2.zip
  • Added support for the Hue Motion Sensor, including the motion, temperature and luminance sensors that are part of the Hue Motion Sensor. NOTE: the following caveats with the motion sensor.
    • Motion detection works, but is delayed by 2 seconds or more (depending on how many other devices you have connected to your Hue hub).
    • Motion detection activity can be somewhat "chatty", at least in my tests, possibly causing more log activity than you're used to. The Hue Motion Sensor changes to the "off" state within a few seconds of when motion stops in the room, so it's not like INSTEON or Z-Wave sensors that have a long delay before sending the "off" message after motion stops.
  • Fixed a bug that caused repeated errors and high CPU load if a Hue Lights device was duplicated in the Indigo UI then the model was changed to a different type of Hue Lights device.
  • Greatly improved the rewritten device update timing from (private beta version) 1.6.0b1 so all device types are updated on a more consistent basis.
  • Improved device update efficiency so that states that haven’t changed are repeatedly updated.
  • Rewrote device update timing to better support sensor devices.
  • Rewrote status update methods for all Hue devices to improve code readability and efficiency.
  • Fixed a bug that allowed you to pick a Hue Group as a Recall Preset destination then return an error when attempting to execute the Recall Preset action. The Recall Preset action does not currently support Hue Groups as a destination device.
  • Fixed a bug in the update check function that would incorrectly notify of updates for older versions if the installed version was a pre-release beta.
Fri May 26, 2017 3:21 am
nsheldon offline
Version 1.6.0 Posted
  • Improved device update efficiency so that states that haven’t changed aren't repeatedly updated.
  • Reworked device update timing to better support sensor devices.
Sat Jun 03, 2017 12:06 am
nsheldon offline
Version 1.6.1 Posted
  • Fixed a bug that caused an error when clicking the Send Status Request button in the Indigo UI for Hue Motion Sensor devices.
  • Added support for another Hue Ambiance bulb (model ID LTC001).
Sat Jun 10, 2017 1:57 pm
nsheldon offline
Version 1.6.2 Posted
  • Fixed a rare bug that caused an error when updating the status of the Hue Motion Sensor luminance setting after the Hue hub became unreachable, then became reachable again.
Wed Jul 19, 2017 11:02 pm
nsheldon offline
Version 1.6.3 Posted
  • Fixed a bug that caused the plugin to crash if a Hue Group had no brightness value.
Tue Aug 01, 2017 10:06 pm
nsheldon offline
Version 1.6.4 Posted
  • Fixed incorrect Hue Motion Sensor light level calculations. The correct lux value is now shown for the light sensor on the Hue Motion Sensor.
Sat Aug 12, 2017 11:42 pm
nsheldon offline
Version 1.6.5 Posted
  • Added support for the IKEA dimmable light identified by “TRADFRI bulb E27 opal 1000lm” when paired to the Hue hub.
Sat Sep 02, 2017 1:45 pm
nsheldon offline
Version 1.6.6 Posted
  • Added support for the Osram Classic A60 RGBW color bulb.
  • Added support for the Osram Flex RGBW color light strip.
  • Added support for the Osram PAR16 50 TW color temperature bulb.
  • Updated the supported features of the Osram Classic A60 TW color temperature bulb to correctly reflect its color temperature support.
Wed Oct 25, 2017 7:24 pm
nsheldon offline
Version 1.6.7 Posted
  • Added support for another Hue GU10 bulb model (LTW015).
  • Added support for minimum and maximum color temperature ranges of color temperature lights in Indigo 7.1.
Thu Oct 26, 2017 10:42 pm
nsheldon offline
Version 1.6.8 Posted
  • Added support for another IKEA dimmable light (E26 model).
Thu Nov 16, 2017 12:53 am
nsheldon offline
Version 1.6.9 Posted
  • Fixed various Unicode decoding issues that could cause the plugin to crash if Hue hub scenes or other objects contained non-ASCII characters.
  • Added support for the Innr RS-128T GU10 color temperature lights.
Mon Nov 20, 2017 1:38 am
nsheldon offline
Version 1.6.10 Posted
  • Added support for all the latest Philips Hue light models listed in Hue API.
Sat Dec 09, 2017 1:15 am
nsheldon offline
Version 1.6.11 Posted
  • Added the ability to set the total number of Presets from within the Hue Lights plugin configuration window.
  • Added a custom plugin icon to plugin bundle.
Mon May 07, 2018 12:30 am
nsheldon offline
Version 1.6.12 Posted
  • Added support for the IKEA 30 Watt dimmable LED transformer.
Mon Jun 18, 2018 3:00 am
nsheldon offline
Version 1.6.13 Posted
  • Added support for the Innr SP 120 On/Off Plugin module.
  • Added support for the IKEA 30x90 color temperature LED panel.
Page 7 of 13 1 ... 4, 5, 6, 7, 8, 9, 10 ... 13
