kmarkley wrote:Manual unlock and lock:Z-Wave received "Lock-Front" status update unlocked (manually)
Z-Wave Lock Manager Debug Raw: 01 0F 00 04 00 04 09 71 05 16 01 00 FF 06 02 00 FF
Z-Wave Lock Manager Status: Door unlocked manually [Node: 4]
Z-Wave received "Lock-Front" status update locked (manually)
Z-Wave Lock Manager Debug Raw: 01 0F 00 04 00 04 09 71 05 15 01 00 FF 06 01 00 FF
Z-Wave Lock Manager Status: Door locked manually [Node: 4]
Indigo unlock and lockZ-Wave sent "Lock-Front" unlock
Z-Wave Lock Manager Debug Door: 01 0D 00 04 00 04 07 62 03 00 00 02 FE FE FF
Z-Wave Lock Manager Status: Door is unlocked [Node: 4]
Z-Wave Lock Manager Latch open, Bolt unlocked, Door open [Node: 4]
Z-Wave sent "Lock-Front" lock
Z-Wave Lock Manager Debug Door: 01 0D 00 04 00 04 07 62 03 FF 00 00 FE FE FF
Z-Wave Lock Manager Status: Door is locked [Node: 4]
Z-Wave Lock Manager Latch open, Bolt locked, Door open [Node: 4]
kmarkley wrote:I should add that after all the above, the Lock Manager device shows "lockState = Open"
Z-Wave Lock Manager Debug Node ID 4 (Hex 4) found in lockIDs
Z-Wave Lock Manager Debug Raw command: 01 08 00 04 00 04 02 98 40 2D
Z-Wave Lock Manager Debug Raw command: 01 0D 00 04 00 04 07 62 03 00 00 02 FE FE FF
Z-Wave Lock Manager Debug Node: 4
Z-Wave Lock Manager Debug Type: 0
Z-Wave Lock Manager Debug User: 0
Z-Wave Lock Manager Debug Updating state: lockState
Z-Wave Lock Manager Debug Updating state: doorState
Error device "Lock-Front-Manager" state key doorState not defined (ignoring update request)
Z-Wave Lock Manager Debug Raw command: 01 21 00 04 00 04 1B 98 81 AC D8 ED 52 11 88 8E 98 F0 3D 88 1B 08 3C FA E4 A0 BC F9 B8 39 E3 74 8A C4 51
Z-Wave Lock Manager Debug Raw command: 01 0D 00 04 00 04 07 62 03 FF 00 00 FE FE FF
Z-Wave Lock Manager Debug Type: 255
Z-Wave Lock Manager Debug Raw command: 01 21 00 04 00 04 1B 98 81 58 5B 26 1C 7E 2A ED 0D A4 16 DB 25 6D 46 9B DB 7B 5B 1A 8B 6A B0 DC 25 D6 32
Z-Wave Lock Manager Debug setRelock action called
Z-Wave Lock Manager Debug Indigo lock selected: 1841050451
Z-Wave Lock Manager Enabling auto relock mode with a timeout of 30 seconds:
Z-Wave sent "Lock-Front" raw command [70 04 02 01 FF]
Z-Wave sent "Lock-Front" raw command [70 04 03 01 1E]
Z-Wave Watcher Debug Raw command sent (Node 4): 01 09 00 13 04 02 98 40 25 92 8C (True)
Z-Wave Watcher Debug Raw command sent (Node 4): 01 1E 00 13 04 17 98 81 01 A4 1C 76 B3 E9 AE 49 A9 49 DA 31 63 4A D7 B0 D7 32 88 70 A5 25 93 C1 (True)
Z-Wave Watcher Debug Raw command sent (Node 4): 01 11 00 13 04 0A 98 80 E6 BF A3 C2 E6 91 7E DC 25 94 B7 (True)
Z-Wave Watcher Debug Raw command received (Node 4): 01 08 00 04 00 04 02 98 40 2D
Z-Wave Watcher Debug Raw command received (Node 4): 01 0D 00 04 00 04 07 62 03 FF 00 00 FE FE FF
Z-Wave Watcher Debug Raw command received (Node 4): 01 21 00 04 00 04 1B 98 81 9A 1D F7 CC AD FB 13 4B 20 D7 F5 1B BA 5D 76 DA E6 4D FD 9E 05 62 AE 50 7C 11
Z-Wave Watcher Debug Raw command sent (Node 4): 01 09 00 13 04 02 98 40 25 95 8B (True)
Z-Wave Watcher Debug Raw command sent (Node 4): 01 1E 00 13 04 17 98 81 72 7D DF 52 8F F6 C6 0D 66 A2 B9 24 7D 9E 1B 58 5F B4 FC 67 60 25 96 92 (True)
Z-Wave Watcher Debug Raw command sent (Node 4): 01 11 00 13 04 0A 98 80 38 E3 72 74 CE A0 31 A7 25 97 7C (True)
Z-Wave Watcher Debug Raw command received (Node 4): 01 0D 00 04 00 04 07 62 03 00 00 02 FE FE FF
Z-Wave Watcher Debug Raw command received (Node 4): 01 21 00 04 00 04 1B 98 81 9D 3F A6 90 15 2E 05 B1 C4 E6 B2 28 6B C1 AC CC 38 D2 A1 0F 9B 64 AF 0B 2E 84
matt (support) wrote:If Indigo broadcasted out the unencrypted packet with the encrypted packet that would help you catch that Indigo sent the command, so you could imply that Indigo is the one that did the lock/unlock? Just trying to make sure I understand what the proposal is.
