Player shows as disconnected
Sat Jul 29, 2017 9:15 am
pocster offline
I have some Raspberry Pi's linked up via this plugin on my mac.
They seem to stream from the squeezebox player no issue. The devices though in the indigo window always show as disconnected; though the MAC address is correct.
Any ideas?
ta
Sat Jul 29, 2017 9:22 am
autolog offline
Re: Player shows as disconnected
Any ideas?
ta
Where is the Squeezebox server running?
Sat Jul 29, 2017 9:23 am
pocster offline
Hey!
Everything is running on the same mac.
Cheers
Sat Jul 29, 2017 9:29 am
autolog offline
So you are running the Raspberry Pi's as Players?
pocster offline
Yep exactly
Sat Jul 29, 2017 9:49 am
autolog offline
Not sure why that would be. :?
Presumably the plugin detected the players in the first place. What does the Notes field say it found?
Do you have an ordinary (hardware) players?
What status does the Squeezebox Server show?
What version of the Squeezebox Server are you running?
Sat Jul 29, 2017 9:55 am
pocster offline
Notes field?; where's that?
No ordinary players.
Squeezebox server found pi and seems perfectly happy.
Screen Shot 2017-07-29 at 16.51.36.png (43.47 KiB) Viewed 7055 times
Sat Jul 29, 2017 10:02 am
autolog offline
Notes field is in the Device List - you might need to right click on the Device List headings to reveal it.
I can't see the Mac address in your images. If you edit one of the devices, what does it show as the Address under Type and Mode?
The Mac Address should be in the format 11:22:33:AA:BB:CC
Sat Jul 29, 2017 11:55 am
pocster offline
Still can't see any notes
There is no mac address listed in indigo. But opening the squeezebox player device and doing edit shows the correct MAC address.
Type and model are I assume correct Autolog Squeezebox , squeezebox player
It all looks good; apart from it's like the plugin can't see the players
Sat Jul 29, 2017 2:20 pm
autolog offline
So did you manually add the players or did the plugin discover them when it started and connected to the server?
There may be a problem in the plugin if you manually enter the MAC address - I am not sure.
If the address is not showing then that is probably the problem. :?
I am currently working my way through a change to the Squeezebox plugin to update it for Indigo 7.
However this is taking a back seat while I am working on an update to the Alexa-Hue Bridge plugin.
I won't be able to fix anything with it (if it needs fixing) until I have done that update. :|
Sat Jul 29, 2017 2:29 pm
pocster offline
Appreciate your help
Yeah I had to add them manually they didn't auto discover .
Cheers
Sun Jul 30, 2017 7:09 am
pocster offline
Rebooted everything; including pi's works like a charm :D
Sun Jul 30, 2017 8:01 am
autolog offline
Thanks for letting me know and glad it is working for you. :)
Mon Jul 31, 2017 5:32 am
pocster offline
Yeah it was very strange!
Everything seemed 'right; i.e. no errors or anything ; but didn't connect.
I did reboot practically everything in my electronic universe though 8)
It's a TOP plugin!
