How to install Google home plugin?
Fri Jul 14, 2017 9:40 am
bcondemi offline
Is there a plugin for google home? I can't seem to find it.
I read somewhere about an HA Bridge? but looking for clear instructions how to install this.
Any help would be appreciated.
Thank-you
BC
Fri Jul 14, 2017 10:09 am
Re: How to install Google home plugin?
There isn't a plugin AFAIK.
Fri Jul 14, 2017 2:12 pm
RogueProeliator offline
There is not... the issue is that the Google Home implementation looks for port 80 for the Hue. So the Alexa plugin actually will work for Google Home if you set it to Port 80... but often on OS X the system is already using 80 for web sites, so you would have to disable those first. I still want to look into adding this or adding it to Domotics Pad to run on a spare device, but time has been short lately.
Adam
Fri Jul 14, 2017 2:36 pm
roussell offline
And… Any free time Adam has will be spent adding HTML window support to Domopad! ;)
#isthishowitfeelstobeDurosity?
Terry
Fri Jul 14, 2017 4:47 pm
durosity offline
#yesnowwheresmypluginfortrollingjay?
Fri Jul 14, 2017 8:17 pm
#thesameplacetheMUTEdurositypluginis_undermycontrol_bwahahahaha
Sat Jul 15, 2017 3:46 am
durosity offline
#:-p
Sat Jul 15, 2017 7:54 am
roussell offline
#bestforumfamilyever!
Sat Jul 15, 2017 9:41 am
durosity offline
#doesthatmakejaymybrother
Sat Jul 15, 2017 9:59 am
#durosityistheblacksheepofthefamily
Sat Jul 15, 2017 10:25 am
durosity offline
#jayisadopted
Sat Jul 15, 2017 11:05 pm
jh71283 offline
From looking at the home assistant forums, it looks like GHome have had to change the way the hue action works. It now gets the device list from hue in the cloud, rather than scanning the local network.
Apparently the change was made at Phillips' request, and we should expect Echo to follow suit.
Sun Jul 16, 2017 10:17 am
Hmm, if that is true then perhaps that is the issue with the Echo Show posted elsewhere? That is bad news!
Sun Jul 16, 2017 10:53 am
durosity offline
#thecloudinessofthings
Tue Jul 18, 2017 3:08 am
jh71283 offline
I know, it's such a pain. I have now had to resort to using IFTTT web hooks to trigger things from GHome, but it is not for the faint hearted. I think the best consumer friendly option out there at the moment is to install a SmartThings hub, and have that communicate over MQTT with indigo.
