"Try re-compiling"
Sat Jun 24, 2017 7:44 pm
"Try re-compiling"
All was working fine for weeks, but I had to restart for unrelated reasons. Now:
/opt/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:35
    throw ex;
Error: The module '/opt/local/lib/node_modules/homebridge/node_modules/mdns/build/Release/dns_sd_bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 48. This version of Node.js requires
NODE_MODULE_VERSION 51. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or`npm install`).
    at Object.Module._extensions..node (module.js:598:18)
    at Module.load (module.js:488:32)
    at tryModuleLoad (module.js:447:12)
    at Function.Module._load (module.js:439:3)
    at Module.require (module.js:498:17)
    at require (internal/module.js:20:19)
    at Object.<anonymous> (/opt/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:24:20)
    at Module._compile (module.js:571:32)
    at Object.Module._extensions..js (module.js:580:10)
I wonder if someone who knows what's up with npm could point to some sort of an article regarding best practices for keeping this from happening--or even marginal practices to enable the unwashed to keep homeBridge running when NODE_WHATSIS_VERSION ∞ changes to VERSION ∞.1
Because now I've tried "npm install homebridge" and "npm install homebridge-indigo" and "npm rebuild homebridge" and "npm rebuild homebridge-indigo" and "npm rebuild" and the Home app still says "65 accessories not responding."
Along the way I get a nice peppering of
npm WARN enoent ENOENT: no such file or directory, open '/Users/mike/package.json'
npm WARN mike No description
npm WARN mike No repository field.
npm WARN mike No README data
npm WARN mike No license field.
Sat Jun 24, 2017 9:21 pm
webdeck offline
Re: "Try re-compiling"
You will need to uninstall node and reinstall. I don't know which version of node you have installed originally, but the instructions for moving from node4 to node6 are here: viewtopic.php?f=191&t=16904
You can adjust based on whatever version you have installed (port installed will list everything that is currently installed.)
Sun Jun 25, 2017 12:31 pm
Thanks. Could have sworn I updated already, but maybe not.
Sun Jun 25, 2017 12:40 pm
Just went through this update again (confirming from the thread you linked that I did in fact go through it before, and I ended with the same homebridge.log error again. After the whole
sudo port uninstall npm2
sudo port uninstall nodejs4
sudo rm -fr /opt/local/lib/node_modules/
sudo port install nodejs6
sudo port install npm3
sudo npm install -g homebridge
sudo npm install -g homebridge-indigo
process, which happened with no fuss aside from some warnings about running port selfupdate.
And yes, I quit and restarted home bridge.
Edit: Looks like the problem is either something with not having run port selfupdate, which I now have done, or it is with my launchctl implementation. When I run homeBridge from the terminal, all is fine. The odd thing is that when I use
launchctl load -w ~/Library/LaunchAgents/com.webdeck.homebridge.plist
I can then see home bridge in the activity monitor, but the log gets that error and nothing shows up in the Home app.
Just confirmed this. How can the launchctl load -w ~/Library/LaunchAgents/com.webdeck.homebridge.plist command be pointing to something different from running homebridge -D?
