Update error
Sun Jun 18, 2017 4:03 pm
rgspb offline
Update error
I get this after updating to the newest version:
Sonos Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 47, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 347, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 363, in checkEvents
StandardError: ServerCommunicationError -- timeout waiting for response
Sonos Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sonos SoCo Reactor Ignition...
Sun Jun 18, 2017 10:54 pm
mclass offline
Re: Update error
I am also getting the following error on startup after upgrade - even though I have not ticked the "Polly" box in the plugin configuration drop down. Is this OK?
 Sonos Error                     Error in plugin execution startup:
  File "plugin.py", line 36, in startup
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 265, in startup
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Sonos.indigoPlugin/Contents/Server Plugin/Sonos.py", line 2220, in closedPrefsConfigUi
KeyError: key Polly not found in dict
Wed Jun 21, 2017 1:05 pm
mvignola29 offline
Re: Update error
After Updating to V1.0.4 get the error message below. Hopefully you will be able to resolve
Started plugin "Sonos 1.0.4"
Sonos Your plugin version, v1.0.4, is current.
Sonos Loaded Sonos Favorites... [3]
Sonos Loaded Playlists... [14]
Sonos Loaded RadioTime Favorite Stations... [2]
Sonos Error [Wed Jun 21 14:59:28 2017] Could not retrieve Pandora credentials.
Sonos Error [Wed Jun 21 14:59:28 2017] Could not retrieve secondary Pandora credentials.
Sonos Serving HTTP Streamer on 192.168.1.102 [0.0.0.0], port 8888
Sonos Loaded SiriusXM Stations.. [375]
Sonos Adding ZonePlayer: 192.168.1.77, RINCON_000E58140C8201400, Sonos Family Room
Sonos Adding ZonePlayer: 192.168.1.92, RINCON_B8E937A762CA01400, Sonos Front Yard
Sonos Adding ZonePlayer: 192.168.1.97, RINCON_000E58DC080001400, Sonos Garage
Sonos Adding ZonePlayer: 192.168.1.72, RINCON_000E5822210C01400, Sonos Living Room
Thu Jul 06, 2017 7:37 am
nlagaros offline
Re: Update error
Please go to the plugin configuration and hit the save button. This should take care of that. I forgot to put error handling around the new parameter. Thanks.
