How do I get this sucker to stop grabbing images constantly? I just want to grab a snapshot when motion is detected.
kelmk wrote:How do I get this sucker to stop grabbing images constantly? I just want to grab a snapshot when motion is detected.
bkmar1192 wrote:my front door camera has a minimum sensitivity of 10 and a max of 40
File "plugin.py", line 743, in MasterCamera
File "plugin.py", line 380, in MasterImage
File "plugin.py", line 45, in getSortedDir
OSError: (2, 'No such file or directory', '/Library/Application Support/Perceptive Automation/Indigo 7/IndigoWebServer/video/Cam Breezeway/03 03 2017 17.39.20')
johnpolasek wrote:Selfishly, *I* would only be using it on the recordings, but I can't speak for how others might want to use it. I haven't tried the "current image" option because (as I said, the sat uplink is slow as Tony Romo, which was why I created the static nine panel control page for whenever the driveway sensor trips. But being able to walk the recording would be far better and mean I could get rid of all the kludgey scripts I have to figure out your directory and img_ names to copy to my directory for display... But it seems that letting the current image get out of sync with real time might present a whole lot of problems for getting it back into sync later...
EDIT
Another place that would benefit would be to have an option to manually advance the carousel...When I played with it last night and this morning it works perfectly on the local WIFI network, but skips cameras remotely here at the office because of the time required to serve each image. If it just grabbed a single frame from each next camera in the queue on manual command and left it up till the next "advance" command, it would work a lot better for slow connections, Please remember that not all of us live in gigabit cities with universal LTE coverage; when you've got to deal with Hughesnet and 3G, things happen a lot slower.
Different Computers wrote:I don't understand why I keep seeing this error over and over:I mean, I get that the directory doesn't exist, but I don't understand why the plugin wants this particular directory, and why it isn't there, and why it doesn't add it if it has to have it.
- Code: Select all
The plugin is set to display a recording that does not exist
