Problems with some devices
Sun May 28, 2017 2:20 pm
MarcoGT offline
Hi all,
today I come back from a short holiday and I noticed that I was not able to switch on/off Fibaro wall plugs using Siri; I tried using Indigo Client on Mac and it is not working either.
This is what I get in the log (some of them are old devices which I do not used; device 29, 35, 37, 38, 39 and 41 are Fibaro Wall Plug)
connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 008 - Relay Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 009 - Motor Control Class B
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 019 - Relay Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 021 - Binary Sensor (routing)
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 023 - Dimmable Power Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 024 - Relay Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 025 - Dimmable Power Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 029 - Relay Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 032 - Binary Sensor (routing)
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 033 - Binary Sensor (routing)
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 035 - Relay Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 036 - Binary Sensor (routing)
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 037 - Relay Power Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 038 - Relay Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 039 - Relay Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 040 - Relay Switch
  Z-Wave                          found module included in controller with no matching device (missing or disabled): 041 - Relay Switch
What is going on?
I did no changes while I was on holiday, nobody worked on it.
Also some Fibaro Window/Door sensor are not responding.
The corresponding device are greyed out in Indigo.
Z-Wave interface reload did not help; also Indigo Server restart did not help.
Marco
Sun May 28, 2017 2:33 pm
MarcoGT offline
Re: Problems with some devices
Ok, this is what I found on log on the 26th (when the "lastUpdate" of the device was successful)
2017-05-27 02:01:36.571   Z-Wave Error   exc type is <type 'exceptions.StandardError'>
2017-05-27 02:01:36.572   Z-Wave Error   restarting serial connection in 5.0 seconds
2017-05-27 02:01:40.048   Interface Failure   lost connection with interface
2017-05-27 02:02:20.684   Z-Wave   connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
2017-05-27 02:02:31.713   Z-Wave   found module included in controller with no matching device (missing or disabled): 008 - Relay Switch
2017-05-27 02:02:31.833   Z-Wave   found module included in controller with no matching device (missing or disabled): 009 - Motor Control Class B
2017-05-27 02:02:31.919   Z-Wave   found module included in controller with no matching device (missing or disabled): 019 - Relay Switch
2017-05-27 02:02:31.932   Z-Wave   found module included in controller with no matching device (missing or disabled): 021 - Binary Sensor (routing)
2017-05-27 02:02:31.943   Z-Wave   found module included in controller with no matching device (missing or disabled): 023 - Dimmable Power Switch
2017-05-27 02:02:31.947   Z-Wave   found module included in controller with no matching device (missing or disabled): 024 - Relay Switch
2017-05-27 02:02:31.950   Z-Wave   found module included in controller with no matching device (missing or disabled): 025 - Dimmable Power Switch
2017-05-27 02:02:39.347   Z-Wave Error   module 029 included in controller no longer matches device "Presa Televisione" type (controller module type: zwDimmerType/zwDimmerType (4, 17, 1), indigo device type: zwRelayType (4, 16, 0))
2017-05-27 02:02:39.373   Z-Wave Error   module 032 included in controller no longer matches device "Finestra CamerettaDx" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 0), indigo device type: zwOnOffSensorType (4, 32, 1))
2017-05-27 02:02:39.392   Z-Wave Error   module 033 included in controller no longer matches device "Finestra CameraDx" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 17, 1), indigo device type: zwOnOffSensorType (4, 32, 1))
2017-05-27 02:02:39.410   Z-Wave Error   module 035 included in controller no longer matches device "Presa Microonde" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 32, 1), indigo device type: zwRelayType (4, 16, 0))
2017-05-27 02:02:39.425   Z-Wave Error   module 036 included in controller no longer matches device "Finestra DivanoSx" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 0), indigo device type: zwOnOffSensorType (4, 32, 1))
2017-05-27 02:02:50.253   Z-Wave Error   failed to get module 036 info from controller (ServerCommunicationError -- timeout waiting for response)
2017-05-27 02:02:50.260   Z-Wave Error   module 037 included in controller no longer matches device "Presa Terrazza" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 32, 1), indigo device type: zwRelayType (4, 16, 1))
2017-05-27 02:02:50.276   Z-Wave Error   module 038 included in controller no longer matches device "Presa Divano" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 32, 1), indigo device type: zwRelayType (4, 16, 0))
2017-05-27 02:02:57.541   Z-Wave Error   module 039 included in controller no longer matches device "Presa iMac" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 32, 1), indigo device type: zwRelayType (4, 16, 0))
2017-05-27 02:02:57.553   Z-Wave   found module included in controller with no matching device (missing or disabled): 040 - Binary Sensor (routing)
2017-05-27 02:02:57.561   Z-Wave Error   module 041 included in controller no longer matches device "Presa Tablet" type (controller module type: zwRelayType/zwRelayType (4, 16, 1), indigo device type: zwRelayType (4, 16, 0))
2017-05-27 02:02:57.571   Z-Wave Error   to re-enable the devices with new z-wave modules, press the "Define and Sync..." button in the device dialog
Sun May 28, 2017 2:41 pm
MarcoGT offline
As suggested in the logs, a resync solved the problem of the wall plugs, not of the Fibaro Door Sensor which are battery powered, need to press the button to wake them up.
But what happened exactly?
Mon May 29, 2017 2:21 pm
marketability offline
I'm having the same problem
started after adding a new device that was on the edge of z-wave range
disabled comms for that device and then other devices throw the error messages above
Tue May 30, 2017 8:57 am
Which messages? There are two sets above which mean very different things...
Tue May 30, 2017 11:04 pm
For me its the:
type
I removed the newly added devices, and its only happened once since
if it happens again I'll post the event log entries
Wed May 31, 2017 8:57 am
A resync should fix that problem - no need to delete and re-add.
Wed May 31, 2017 11:27 pm
Hi Jay
The issue is recurring and with seemingly different devices each time -= any suggestions?
some devices resent OK while others refuse.
Last night's event log entries...
31 May 2017, 23:33:16
   Z-Wave Error                    no ack/nak/busy reply (046) for requestMeterLevel (re-sending)
31 May 2017, 23:33:49
   Hue Lights                      received "Motion Toilet Temp" sensor update to 15.9 ºC
   Z-Wave Error                    send "Power TV" requestMeterLevel command failed (module might be asleep, or is unreachable)
   Z-Wave                          received "Power TV" power load to 7.5 W
31 May 2017, 23:34:38
   Z-Wave Error                    send requestMeterLevel failed after 9 attempts
31 May 2017, 23:35:23
   Z-Wave                          connected to Z-Wave 3.95 static controller interface on /dev/cu.usbmodem1421 (firmware 1.00)
   Z-Wave Error                    module 024 included in controller no longer matches device "024 - Remote Double Switch (ZME-WALLC-S)" type (controller module type: zwDimmerType/zwDimmerType (4, 33, 1), indigo device type: zwDimmerType (4, 24, 1))
   Z-Wave Error                    module 027 included in controller no longer matches device "Shed Garden" type (controller module type: zwCustomType/zwCustomType (4, 24, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 028 included in controller no longer matches device "MultiHallway 028 - Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 33, 1))
   Z-Wave                          found module included in controller with no matching device (missing or disabled): 031 - Multilevel Sensor (routing)
   Z-Wave Error                    module 032 included in controller no longer matches device "Power Echo Dining" type (controller module type: zwValueSensorType/zwValueSensorType (4, 33, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 034 included in controller no longer matches device "Door Outside Strip 034 - Door/Window Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 035 included in controller no longer matches device "Scene Master 1035 - Scene Master (ZRC-90)" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwCustomType (1, 1, 6))
   Z-Wave Error                    module 036 included in controller no longer matches device "Power Amp Patio" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 037 included in controller no longer matches device "Flood Toilet" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (1, 1, 6), indigo device type: zwOnOffSensorType (4, 161, 2))
   Z-Wave Error                    module 038 included in controller no longer matches device "Flood Bathroom" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 161, 2))
   Z-Wave Error                    module 039 included in controller no longer matches device "MultiKitchen 039 - Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 161, 2), indigo device type: zwOnOffSensorType (4, 33, 1))
   Z-Wave Error                    module 040 included in controller no longer matches device "Power Speaker Bed2" type (controller module type: zwCustomType/zwCustomType (4, 161, 2), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 041 included in controller no longer matches device "Power Speaker Bed1" type (controller module type: zwValueSensorType/zwValueSensorType (4, 33, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 042 included in controller no longer matches device "Door Lounge" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 043 included in controller no longer matches device "MultiLounge2 - Motion" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 16, 1), indigo device type: zwOnOffSensorType (4, 7, 1))
   Z-Wave Error                    module 045 included in controller no longer matches device "Power Printer" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 046 included in controller no longer matches device "Power TV" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwRelayType (4, 16, 1))
   Z-Wave Error                    module 047 included in controller no longer matches device "MultiBedroom 047 - Motion Sensor" type (controller module type: zwOnOffSensorType/zwOnOffSensorType (4, 7, 1), indigo device type: zwOnOffSensorType (4, 33, 1))
Thu Jun 01, 2017 10:07 am
It could be a few different things. The Z-Stick is reporting incorrect information for all of those nodes. It could be malfunctioning. It could also be a bad USB connection. Do you have it plugged directly into the Mac (which is what we recommend)? It could also just be in a bad state.
If re-syncing the modules only temporarily fixes it, then you could try a full factory reset of the Z-Stick (last menu item in the Interfaces->Z-Wave menu). You'll have to exclude and re-include the modules after that, so it is somewhat of a pain but probably worth trying before you try a replacement Z-Stick. First thing though would be to make sure it is plugged directly into your Mac (then re-sync to get the modules working again).
Thu Jun 01, 2017 10:20 am
Thanks Jay
It is plugged directly into the iMac
I might just go for a new stick. If I go to all the effort of excluding and re-including - wouldn't want to do it again if I need a new stick :-)
Will crack open a few beers - that might help
