When is the next release of Indigo Touch?
Sat Apr 22, 2017 2:48 am
Turribeach offline
Re: When is the next release of Indigo Touch?
Some of us can't take that risk. I don't have access to my home without IT.
Not true. You can access you "home" by just using a standard internet browser and the same URL you use in Indigo Touch (with the same username and password). Pretty much all the functionality that Indigo Touch has you can access via the browser, including control pages. I think the only thing missing is looking at the event logs. This even works from Safari in iOS (see screen shots below).
To be honest I am not sure what's your urgency. It's a one off warning which you can easily dismiss. If we had iOS 11 out and Indigo Touch wasn't working then I will be shouting with you. But at the moment is merely a minor inconvenience which I expect to be fixed before it becomes a problem.
Sat Apr 22, 2017 12:46 pm
We have every intention of having an updated release of Indigo Touch available before Apple discontinues support for 32 bit applications.
Fri May 12, 2017 2:27 pm
RAID5 offline
Is it just my iPad or did the latest update 10.3.1 fix something, I have removed Indigo touch regular with 3-5 days interval. Now I haven't done it for at least 2 weeks. Still plenty of free space.
RAID5 "A happy Swede addicted to automation"
Fri May 12, 2017 3:06 pm
Hopefully Apple fixed the caching bug...
Fri May 12, 2017 3:28 pm
Don't know if it related. But for some time now it takes a long time for itouch to find and connect to the indigo server locally. Through the cell phone net it is faster.
Fri May 12, 2017 3:30 pm
Turribeach offline
It's fine for me both ok wifi at home and via cellular data. Are you using the reflector? I noticed there is a lag when using hence I switched back to a direct connection.
Fri May 12, 2017 3:39 pm
Slow with reflector when it does the bonjour connect
Fri May 12, 2017 4:21 pm
RAID5 offline
I have seen on my iPhone once that the name (Indigo Touch) under the logo changed very briefly to "clearing cache" or something similar. Is that what you are referring to Jay?
Fri May 12, 2017 4:41 pm
I haven't seen that before, but that very well might be iOS cleaning up all the cached images. It would be fantastic if they've fixed the bug. I was just about to add a manual clear cache button to Indigo Touch (probably still will...).
Fri May 12, 2017 5:27 pm
durosity offline
Please do Matt, whenever I tweak control page images it takes a fair while for it to update on devices without removing the app and reinstalling.
Thu May 18, 2017 5:11 pm
durosity offline
Quick idea for next indigo touch.. pulling down on a device page forcing a status check update. Could be quite handy for a couple of troublesome devices
Sun Jun 04, 2017 1:13 pm
Brady offline
I wasn't expecting this until iOS 11, but it seems that all 32bit applications have now been removed from App Store search results.
Searching for Indigo Touch brings back nothing. Direct links to the app still load...
Just wanted to make everyone aware. Will probably be getting questions incoming from a few confused customers ;-)
Sun Jun 04, 2017 3:15 pm
Searching for Indigo seems to work for me. But, in any event, v2.1 is being tested now and depending on what's found should be available in the next several weeks.
Sun Jun 04, 2017 3:23 pm
Turribeach offline
I think it was a "system glitch" or perhaps a trial run of the changes coming in iOS 11? I also searched when Brady posted and it didn't find Indigo Touch. I searched now and it's the top result. In any case it's no secret that Apple's App Store search is badly broken and barely useful. Most people recommend using Google and then click on the link to be redirected to the App Store page.
Sun Jun 04, 2017 7:05 pm
Same here. Searched earlier and IT wasn't in the results. Just searched again and it's back.
