shmigator wrote:The plugins log settings are set to high. I restarted Indigo and ran it for a bit, but log looks the same.
shmigator wrote:Now to just figure out a cool way to show it on a control page ....
Enphase Envoy Plugin Error connecting to Device:Enphase SolarPanel 9Error is:key sourceXML not found in dict
Error device "Enphase SolarPanel 9" state key powerStatus not defined (ignoring update request)
Enphase Envoy Plugin Error Error in plugin execution MenuAction:
File "plugin.py", line 208, in checkForUpdates
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 86, in checkForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 178, in _prepareForUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 95, in getUpdate
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 120, in getLatestRelease
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EnphaseEnvoy.indigoPlugin/Contents/Server Plugin/ghpu.py", line 148, in _GET
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1053, in request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1093, in _send_request
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1049, in endheaders
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 893, in _send_output
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 855, in send
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/httplib.py", line 1274, in connect
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 352, in wrap_socket
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 579, in __init__
File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/ssl.py", line 808, in do_handshake
SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:590)
mclass wrote:Great plugin thanks Glenn!
Just commissioned an 11 panel system and integrated with Indigo V7.1.1 using your plugin V0.1.6 which was quite straightforward. - thanks!!
mclass
You will note that the individual panel outputs reported by each of the IQ7 micro inverters do not sum to the production figure reported by the Envoy-S. The discrepancy seems higher than losses and metering errors that might occur.
- The Custom States listed for each of the panel devices do not correlate to the states presented when editing a control panel. Is this a plugin, Indigo or operator issue? For example, when designing the control panel I have selected the "Power Generated" device state although the Custom State on the panel device is "watts".
- If I "Refresh Data Now" from the Plugin menu I get the following error for each panel device (just one is listed here, but all 11 panels generate the same error):
mclass wrote:Wow! That was quick, thanks.
I’m away from mr computer but will check ASAP.
Re the daily production, am I correct in assuming that this is watthr and not watts?
Thanks again!
mclass
mclass wrote:Thanks!
My use case is relatively straightforward, as I don’t have a time of day tariff, but I understand that others may do.
Happy (and productive!) thinking
mclass
