It would be useful if when double clicking on a plugin to install it, Indigo had the option to Re-Install and Enable if it is the plugin version hasn't changed. At the moment you only get the option to Enable if Necessary.
To get round this you need to edit the existing plugin's info.plist to an older version number and then reload it before doing the install again.
Thanks for considering.
