Harmony Hub Won't Start
Mon Jan 02, 2017 1:00 pm
dnomode offline
Re: Harmony Hub Won't Start
Ugh… What a drag.
The commands did not work, however I just manually copied the files from "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages" to "/Library/Python/2.7/site-packages" and now its working. :D Thanks…
Is there a way that I can uninstall all of the old stuff and re-install correctly? I don't want to have problems in the future.
Thanks for your help.
Edmond
Mon Jan 02, 2017 1:05 pm
FlyingDiver online
dnomode wrote:
Ugh… What a drag.
Edmond
Since I don't know how you installed it in the first place, I don't know how you would uninstall it.
But if you remove /Library/Frameworks/Python.framework/Versions/3.5/bin and /Library/Frameworks/Python.framework/Versions/2.7/bin from your $PATH, that should sort of fix it. I think you'll need to edit .profile in your home directory to do that.
Sun Mar 12, 2017 3:19 pm
jens offline
Cant get the plugin to start. :(
get this error
Reloading plugin "Harmony Hub 7.1.0"
Starting plugin "Harmony Hub 7.1.0" (pid 24250)
Harmony Hub Error Error in plugin execution InitializeMain:
File "plugin.py", line 9, in <module>
ImportError: No module named sleekxmpp
Stopping plugin "Harmony Hub 7.1.0" (pid 24250)
Stopped plugin "Harmony Hub 7.1.0"
//Jens
Sun Mar 12, 2017 4:20 pm
FlyingDiver online
get this error
//Jens
Did you install sleekxmpp per the instructions in the ReadMe.md file?
Wed Mar 15, 2017 10:12 am
jens offline
Yes I did,
Wed Mar 15, 2017 10:43 am
FlyingDiver online
jens wrote:
Yes I did,
Well, you did it wrong. The error message is very clear. The Python interpreter Indigo is using isn't finding the library. That's usually caused by a non-standard Python install. There are multiple threads about this problem on this forum.
I can't help anymore this week. I'm out of town with just my iPad.
Wed Mar 15, 2017 11:12 am
jens offline
Not so good on the type of installation, then yes something I have done wrong, I hope you or anyone else can help me,
running Indigo 7
// Jens
Thu Mar 16, 2017 8:33 am
Open a terminal window and paste in the following lines:
which python
python --version
pip list
Copy/paste the results in a code block here.
Thu Mar 16, 2017 10:16 am
jens offline
/Users/mini/Downloads/WUnderground\ Icon\ Pack Minis-Mac-mini:~ mini$ which python
/Library/Frameworks/Python.framework/Versions/2.7/bin/python
Minis-Mac-mini:~ mini$ python --version
Python 2.7.11
Minis-Mac-mini:~ mini$ pip list
matplotlib (1.1.1)
pid (2.1.1)
pip (7.1.2)
requests (2.11.1)
setuptools (18.2)
sleekxmpp (1.3.1)
vsure (0.11.1)
You are using pip version 7.1.2, however version 9.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
//Jens
Thu Mar 16, 2017 10:35 am
That looks wrong - specifically, the which command output shouldn't look like that. Try these:
ls -l /usr/bin/python
/usr/bin/python --version
ls -l /usr/local/Cellar
(I added the code block to your post - it makes it easier to read terminal command output, please put your followup in a code block)
Thu Mar 16, 2017 10:45 am
FlyingDiver online
I'm pretty sure that's where the Python download installer (from python.org) puts it. Usually the result of installing P2.7 on a system that doesn't have it. Then when the OS was upgraded, it became redundant.
Just guessing.
Thu Mar 16, 2017 11:23 am
jens offline
manually copy the files to this "/Library/Python/2.7/site-packages". from "/Library/Python/2.6/site-packages
And now it works :)
Thanks....
//Jens
Thu Mar 16, 2017 11:26 am
Well, no, the path is correct for the OS install. However, the which command should output:
/usr/bin/python
rather than the full path to the OS install. So something is jacking with paths. My guess is it's the homebrew install, and that /usr/bin/python is actually a link to the homebrew install.
Thu Mar 16, 2017 11:27 am
And now it works :)
I don't see how that's possible. Indigo 7 uses python 2.7, not 2.6, so putting it into the 2.6 release's site-package directory wouldn't have made any difference...
In any case, glad it's now working.
Thu Mar 16, 2017 11:30 am
FlyingDiver online
jay (support) wrote:
And now it works :)
He copied it the othe way, from 2.6 to 2.7. Sounds like it's running the wrong pip command.
