Line Style question?
Sat Feb 25, 2017 9:15 am
autolog offline
First off: this is a great plugin - thanks for your efforts Dave, it's much appreciated. :D
I am trying to create a graph to monitor the temperature and setpoint for a room.
Is there a way to plot a line so that it gives a right angle rather than sloped lines.
I am OK with the temperature being shown as joined lines but the heat setpoint would be better shown as rectangular.
So if I have the following CSV data (example):
Time        Temp      Setpoint
18:00      18.0        6
18:10      18.0        6
18:20      17.9       28
18:30      18.1       28
18:40      18.7       28
18:50      19.5        6
19:00      19.7        6
19:10      18.5        6
Then I would like the setpoint line to track horizontally along the 6 deg C Y-axis and then at 18:20 go vertically to 28 and then track horizontally along the 28 deg C Y-axis until 18:50 where it would descend to 6 deg C and then track horizontally along the 6 deg C Y-axis (if that all makes sense) - so you end up with rectangular shapes. So all changes are done in the vertical.
In the mean while the Temp line would track by joining the dots i.e. as it does at the moment.
Is this possible?
Sat Feb 25, 2017 1:10 pm
Re: Line Style question?
Thanks Jon - that's high praise coming from you. Appreciated!
If I understand, you want something like this:
I think it should be doable. It requires the data to to be shifted slightly (note that my y2 values are different than yours).
#! /usr/bin/env python
# -*- coding: utf-8 -*-
import datetime as dt
import matplotlib.pyplot as plt
import matplotlib.dates as mdates
x_values = ['18:00', '18:10', '18:20', '18:30', '18:40', '18:50', '19:00', '19:10']
y1_values = [18.0, 18.0, 17.9, 18.1, 18.7, 19.5, 19.7, 18.5]
y2_values = [6, 6, 6, 28, 28, 28, 6, 6]
fig, ax = plt.subplots()
final_x_values = [dt.datetime.strptime(x, "%H:%M") for x in x_values]
ax.plot(final_x_values, y1_values)
ax.step(final_x_values, y2_values)
timeFmt = mdates.DateFormatter('%H:%M')
ax.xaxis.set_major_formatter(timeFmt)
plt.show()
I've had the idea of adding a step option in the back of my mind; I'll move it to the front. :D
Sat Feb 25, 2017 2:32 pm
autolog offline
Hi Dave,
Yes that is it exactly :)
Sat Feb 25, 2017 2:51 pm
Cool -- I'll make some effort and see what I can gin up.
Sat Feb 25, 2017 4:43 pm
Seems matplotlib already thought of the need to shift the observations with 'steps-post' which will eliminate the need to modify the data before plotting it.
y2_values = [6, 6, 28, 28, 28, 6, 6, 6]
ax.plot(final_x_values, y2_values, ls='steps-post')
yearsFmt = mdates.DateFormatter('%H:%M')
ax.xaxis.set_major_formatter(yearsFmt)
plt.show()
Sat Feb 25, 2017 5:20 pm
autolog offline
Hi Dave,
Excellent - thanks for looking into it. :)
Sun Feb 26, 2017 1:37 pm
autolog offline
Hi Dave,
Image as requested. :)
In case it helps, the csv data:
"2017-02-26 15:08:55.459161","1"
"2017-02-26 15:29:41.349360","1"
"2017-02-26 15:36:13.326643","0"
"2017-02-26 15:37:07.342293","0"
"2017-02-26 15:42:05.359670","0"
"2017-02-26 15:44:59.337613","1"
"2017-02-26 15:53:17.320798","1"
"2017-02-26 15:56:17.324108","1"
"2017-02-26 16:01:15.310976","1"
"2017-02-26 16:25:54.287945","1"
"2017-02-26 16:29:39.020370","1"
"2017-02-26 16:30:36.468232","1"
"2017-02-26 16:31:46.317357","1"
"2017-02-26 16:32:02.290467","1"
"2017-02-26 16:46:43.288328","0"
"2017-02-26 18:30:39.169850","1"
"2017-02-26 18:43:36.176026","1"
"2017-02-26 18:43:38.153418","1"
"2017-02-26 18:51:38.997011","1"
"2017-02-26 18:55:00.104274","1"
"2017-02-26 19:00:00.105917","0"
"2017-02-26 19:05:00.100504","0"
"2017-02-26 19:10:00.100116","0"
"2017-02-26 19:15:00.103663","0"
"2017-02-26 19:20:00.084704","0"
"2017-02-26 19:25:00.082249","0"
"2017-02-26 19:30:00.076642","1"
"2017-02-26 19:35:00.071042","1"
Sun Feb 26, 2017 3:33 pm
Thanks Jon - that's what I thought. Looks like the fill is being applied as a typical line plot. I'll see what I can do about that.
Cheers,
Dave
Sun Feb 26, 2017 4:18 pm
autolog offline
Hi Dave,
Many thanks. :)
Sun Feb 26, 2017 9:09 pm
After a fair bit of research it doesn't appear to really be possible to fill a stepped plot under the versions of matplotlib that Apple has shipped. @Autolog - I'm going to PM you some code to show a demonstration of why this may not be something to include in the plugin... :D
Dave
Mon Feb 27, 2017 10:28 am
autolog offline
Thought I would share an image of a temperature graph:
The green line represents the setpoint of the radiator thermostat (a Popp TRV which is at low level, at the bottom of the radiator near the floor).
The red line represents the temperature that is recorded by the POPP TRV.
The yellow line is a wall mounted thermostat which is controlling the setpoint of the the POPP TRV via my Stella-Z plugin (which also determines the heating schedule).
The violet line represents the outside temperature.
It's really great being able to visualise the values and see what effect the settings have. :)
I used to use FHEM before migrating to Indigo and that had an inbuilt graphing facility. This plugin plugs the gap (so to speak) and enables me to have similar functionality to that which I had with FHEM. :D
Mon Feb 27, 2017 12:35 pm
That's awesome. Thanks for sharing your work. That will surely give others some ideas on how they can use the plugin.
Special shout out to Jon for helping me with some great ideas for the plugin, and helping test enhancements. :D
