mclass wrote:Having had a Wemo Insight switch fall into my hands, I have searched the Indigo forums for means to integrate the device with Indigo - without success
Searching further, I have come across a script that I have successfully deployed (with some minor changes) as a series of action groups to turn the Wemo on and off, toggle the state and to determine its state. Regrettably, I am not sufficiently software literate to develop this further into a plugin, but have posted it it in the hope that it may generate further interest in developing support for this and other Wemo devices!
Note that the Wemo app is still required to set up the switch on the local wifi network.
mclass
# Python script to operate or obtain status of Wemo switch
# based on a script WeMo.py published by pruppert on GitHub
# at https://gist.github.com/pruppert/
# Usage:
# Tested with Wemo Mini switch as an embedded script in an
# Indigo Action Group/Virtual Device
#!/usr/bin/python
import re
import urllib2
# Configuration:
# Enter the local IP address of your WeMo in the parentheses of the ip variable below.
# You may have to check your router to see what local IP is assigned to the WeMo.
# It is recommended that you assign a static local IP to the WeMo to ensure the WeMo is always at that address.
# Uncomment one of the triggers at the end of this script.
# Insert the appropriate message for the Indigo event log near line 89
ip = 'insert address here'
WemoVar = "Insert name of Indigo status variable here"
class wemo:
OFF_STATE = '0'
ON_STATES = ['1', '8']
ip = None
ports = [49153, 49152, 49154, 49151, 49155]
def __init__(self, switch_ip):
self.ip = switch_ip
def toggle(self):
status = self.status()
if status in self.ON_STATES:
result = self.off()
# result = 'WeMo is now off.'
elif status == self.OFF_STATE:
result = self.on()
# result = 'WeMo is now on.'
raise Exception("UnexpectedStatusResponse")
indigo.variable.updateValue(WemoVar, value=result)
return result
def on(self):
result = status
result = self._send('Set', 'BinaryState', 1)
return result
def off(self):
result = self._send('Set', 'BinaryState', 0)
result = status
return result
def status(self):
result = self._send('Get', 'BinaryState')
return result
def name(self):
return self._send('Get', 'FriendlyName')
def signal(self):
return self._send('Get', 'SignalStrength')
def _get_header_xml(self, method, obj):
method = method + obj
return '"urn:Belkin:service:basicevent:1#%s"' % method
def _get_body_xml(self, method, obj, value=0):
return '<u:%s xmlns:u="urn:Belkin:service:basicevent:1"><%s>%s</%s></u:%s>' % (method, obj, value, obj, method)
def _send(self, method, obj, value=None):
body_xml = self._get_body_xml(method, obj, value)
header_xml = self._get_header_xml(method, obj)
for port in self.ports:
result = self._try_send(self.ip, port, body_xml, header_xml, obj)
if result is not None:
self.ports = [port]
return result
raise Exception("TimeoutOnAllPorts")
def _try_send(self, ip, port, body, header, data):
request = urllib2.Request('http://%s:%s/upnp/control/basicevent1' % (ip, port))
request.add_header('Content-type', 'text/xml; charset="utf-8"')
request.add_header('SOAPACTION', header)
request_body = '<?xml version="1.0" encoding="utf-8"?>'
request_body += '<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">'
request_body += '<s:Body>%s</s:Body></s:Envelope>' % body
request.add_data(request_body)
result = urllib2.urlopen(request, timeout=3)
return self._extract(result.read(), data)
except Exception as e:
print str(e)
return None
def _extract(self, response, name):
exp = '<%s>(.*?)<\/%s>' % (name, name)
g = re.search(exp, response)
if g:
return g.group(1)
return response
def output(message):
# Write message to Indigo server event log
indigo.server.log ("Wemo Device Name - " + message)
switch = wemo(ip)
# Configuration:
# Uncomment only one of the lines below to make the script work.
#output(switch.on())
#output(switch.off())
output(switch.toggle())
#output(switch.status())
very slick automation through a simple and intuitive cloud services
jay (support) wrote:We continue to evaluate the various technologies out there for inclusion in Indigo, but the demand for Wemo support has thus far been very limited in comparison to other things (Indigo Touch, more extensive Z-Wave support, etc.) that are a much higher priority.
We would certainly love to see a 3rd party developer add Wemo support via a plugin but none seem to be particularly interested at the moment.
DVDDave wrote:FWIW, I'd like to echo what others have said about wanting Wemo support in Indigo. The inexpensive switch from Costco that I integrated has been working very well. I think the inexpensive Wemo units are a good substitute for cheap X10 devices to allow whole home automation at a much lower cost than z-wave, insteon and others. They also work at wifi distances which is farther than other technologies in my experience. Low demand may be a chicken and egg issue since I put off buying one due to lack of Indigo support for them. I finally got it when I saw the script posted by mclass. A plug-in would be ok, and I wish I had the capability of creating one, but I agree with others that Wemo is getting much bigger now as evidenced by Costco selling them. Just my 2 cents. Thanks as always;
jay (support) wrote:Thanks for the feedback. If you look at this thread, for example, I think you'll see what we mean by low demand (mclass only looked into it because one "fell into his hands"). And another interpretation for something showing up in Costco is that they aren't selling well...
But, in any event, now that mclass has done at least part of the work someone else could build the plugin so if there's sufficient demand I'm sure one of our 3rd party developers will pick it up.
rgspb wrote:Just my two cents worth, but I think one reason I would like to see native WeMo support is because these units are a fraction of the cost of Insteon units. They are also more readily available. I have had three new Insteon plug in modules crumble in my hand as I plugged it in. Not saying WeMo is better constructed, but at Insteon prices they should be constructed much better. My older plug in modules are are still rock solid. All this being said I wonder if HomeKit Bridge plug-in gives support for these?
rgspb wrote:I haven’t tried Z-Wave before, I’ve sunk all my fortunes into Insteon. Just ordered a Z-Stick and plug-in module from Amazon so I’ll see how that works with my setup. You’re right in that there are a lot of Z-Wave compatible devices out there. I’m just a little fed up with some of my Insteon devices now and there’s way too many choices to just keep,throwing my money at them.
wideglidejrp wrote:What would be the most reliable solution for smart plugs with Indigo?
