Fibaro KeyFob
Forum rules
Tue Feb 07, 2017 1:37 pm
bluefightingcat offline
Fibaro KeyFob
Any chance of this being added to Indigo? Looks pretty cool:
http://www.fibaro.com/en/products/keyfob/
Wed Feb 08, 2017 4:35 am
Re: Fibaro KeyFob
This should work out of the box with my Zwave Scene Controller plugin until Indigo adds native support.
Wed Feb 08, 2017 4:56 am
Re: Fibaro KeyFob
Wed Feb 08, 2017 9:44 am
andarv offline
Re: Fibaro KeyFob
I use howatp plugin for the nodOn remote
Wed Feb 08, 2017 12:32 pm
Re: Fibaro KeyFob
Yep, as Andarv says.
Mon Feb 27, 2017 2:59 am
dniklewicz offline
Re: Fibaro KeyFob
Unfortunately Fibaro KeyFob is not working out of the box. The only think we can do using the current version of Indigo is to check it's battery level :wink:
Any chance to support it anytime soon?
Derek
Mon Feb 27, 2017 4:50 am
autolog offline
Re: Fibaro KeyFob
Have you tried it with Howartp's Zwave Scene Controller
That will probably give you what you want while you are waiting for Indigo to be updated. :)
Have you sent details to Matt of the the device details so that he can add it?
Mon Feb 27, 2017 9:19 am
Re: Fibaro KeyFob
Anyone found a US retailer with this for sale? Not at NewEgg or Amazon.
Mon Feb 27, 2017 9:46 am
Re: Fibaro KeyFob
Can you copy/paste the Event Log results of the define/sync operation in Indigo with it?
Mon Feb 27, 2017 2:13 pm
dniklewicz offline
Re: Fibaro KeyFob
Hi Matt, thank you for your fast response!
Here is the log for add/sync actions:
controller included module: 034 - Basic Wall Controller
stopped controller inclusion mode
Syncing - started for "034 - Basic Wall Controller"
Syncing - retrieved module neighbors list: 3, 4, 7, 25
Syncing - assigning return route to "034 - Basic Wall Controller"
Syncing - assigned return route
Syncing - retrieved manufacture and model names: Fibaro System - 010F, Basic Wall Controller - 10011000
Syncing - retrieved protocol version 4.38, app version 3.02
Syncing - retrieved class hierarchy: Routing Slave : Wall Controller : Basic Wall Controller (04 : 18 : 01, base 00)
Syncing - retrieved command classes: 80v1 84v2 85v1 86v1 8Ev1 56v1 98v1 59v1 5Av1 5Bv1 5Ev1 20v1 22v1 70v1 72v1 73v1 75v1 7Av1
Syncing - retrieved encrypt commands: - none -
Syncing - retrieved capabilities: routing, battery, beaming, security, waking
Syncing - retrieved wake interval of 0 minutes
Syncing - device "034 - Basic Wall Controller" wake interval changed to 60 minutes
Syncing - retrieved group 1 associations: []
Syncing - retrieved group 2 associations: []
Syncing - retrieved group 3 associations: []
Syncing - retrieved group 4 associations: []
Syncing - retrieved group 5 associations: []
Syncing - retrieved group 6 associations: []
Syncing - retrieved group 7 associations: []
Syncing - retrieved group 8 associations: []
Syncing - retrieved group 9 associations: []
Syncing - retrieved group 10 associations: []
Syncing - retrieved group 11 associations: []
Syncing - retrieved group 12 associations: []
Syncing - retrieved group 13 associations: []
Syncing - retrieved battery level of 46%
Edit:
Adding logs for button press:
received "KeyFob" scene 1    // Button 1 short press
received "KeyFob" scene 2    // Button 2 short press
received "KeyFob" scene 3    // Button 3 short press
received "KeyFob" scene 4    // Button 4 short press
received "KeyFob" scene 5    // Button 5 short press
received "KeyFob" scene 6    // Button 6 short press
received "KeyFob" scene 513     // Button 1 long press
received "KeyFob" scene 257
received "KeyFob" scene 514     // Button 2 long press
received "KeyFob" scene 258
received "KeyFob" scene 515     // Button 3 long press
received "KeyFob" scene 259
received "KeyFob" scene 516     // Button 4 long press
received "KeyFob" scene 260
received "KeyFob" scene 517     // Button 5 long press
received "KeyFob" scene 261
received "KeyFob" scene 518     // Button 6 long press
received "KeyFob" scene 262
Long press generates pair of Z-wave messages (like scene 513 and 257 for button 1).
Sequences of different buttons and series of multiple use of one button can be defined using configuration parameters but I had not time to play with them yet.
Hope this helps!
Derek
Mon Feb 27, 2017 4:38 pm
Re: Fibaro KeyFob
As autolog says, my plugin should work with this out of the box until Matt adds it.
Mon Feb 27, 2017 6:16 pm
dniklewicz offline
Re: Fibaro KeyFob
Unfortunately plugin returns error on every button tap but maybe I am doing something wrong:
Zwave Scene Controller Debug    -----
Zwave Scene Controller Debug    Central Scene Command received:
Zwave Scene Controller Debug    Raw command: 01 0B 00 04 00 24 05 5B 03 08 80 04 05
Zwave Scene Controller Debug    Node:    36
Zwave Scene Controller Debug    Button:  4
Zwave Scene Controller Error    Error in plugin execution ReceivedBroadcast:
  File "plugin.py", line 89, in zwaveCommandReceived
IndexError: list index out of range
Derek
Sat Mar 04, 2017 11:25 am
Re: Fibaro KeyFob
Ah, that fix is coming shortly.
Scene ids from several devices are being sent wrong - 1 is 81, 2 is 82 etc - which I need to trap in the script.
Wed Mar 08, 2017 5:54 pm
Re: Fibaro KeyFob
Here is a beta of Indigo's Z-Wave library that has preliminary support for the keyfob. Re-sync it after you install it (extract it then double-click to install)), and you should then see the trigger options in the UI for all 6 buttons.
Wed Mar 08, 2017 6:31 pm
Re: Fibaro KeyFob
Now THAT'S support!
The fob is supported even before you can buy it on Amazon!
