matt (support) wrote:Can you copy/paste an Event Log example of the problem occurring and described for us in detail how you have your Triggers defined?
Ok, here it goes.
Test Case: I pressed KPL button 4 quickly 4 (four) times. This light is connected to an ApplianceLinc that controls a desk lamp that my 8 year old daughter calls her "lantern". This is a good test case because she often presses this button multiple times because there's a delay in this light turning on for some reason. Don't get too hung up on those details because any repetitive button press on any one of my 3 KPLs creates a similar loop. This one is a 6 button KPL. Hopefully I've done something to create it in the triggers.
The Event Log: In order to end this loop I disabled the comms through the mac Indigo client.
- Code: Select all
Jan 1, 2017, 8:50:17 PM
Received INSTEON "Lexi's Room KPL" on (button 4)
Trigger Lexi's KPL Button 4 ON
Sent INSTEON "Lexi's Lantern" on
Trigger KPL LED For Lexi's Lantern Synch- ON
Received INSTEON "Lexi's Room KPL" off (button 4)
Trigger Lexi's KPL Button 4 OFF
Error "Lexi's Room KPL" keypad button 4 on; send failed (no acknowledgment)
Sent INSTEON "Lexi's Lantern" off
Trigger KPL LED For Lexi's Lantern Synch - OFF
Sent INSTEON "Lexi's Room KPL" keypad button 4 off
Trigger Set house occupied when Ryan comes home
Sent INSTEON "Lexi's Room KPL" keypad button 4 on
Sent INSTEON 1D.FD.5D keypad button 4 on
Trigger Definition: I'm only listing the definition of this button so let me know if you want to see the others too. No conditions set on any:
Lexi's KPL Button 4 ON - On device state changed, Keypad button LED 4 becomes on; Turn on appliance Lexi's Lantern
Lexi's KPL Button 4 OFF - On device state changed, Keypad button LED 4 becomes off; Turn off appliance Lexi's Lantern
KPL LED for Lexi's Lantern Synch ON - On device state changed, Lexi's Lantern becomes on; Turn on keypad button; Lexi's Room KPL; button 4
KPL LED for Lexi's Lantern Synch OFF - On device state changed, Lexi's Lantern becomes off; Turn off keypad button; Lexi's Room KPL; button 4
The last 2 are used to set the button lights on and off so they correctly match the state of the device should I control the light through any other means than the KPL (schedule, Indigo Touch, etc..)
