Latest Version - 2.0.41 NEST Home 1, 2 & 3 (LOCKED)
Thu Dec 22, 2016 4:54 am
stuartcolman offline
Re: Latest Version - 2.0.41 for NEST Home, NEST Home 2 & 3
I've changed over to the latest version as I have a Nest 3, I have been through the config process and it shows in the log that the Plugin is getting the Nest Map from nest.com, it list my devices in the log, however I don't get any further device created in the NEST Home 3 folder.
Am I missing something?
Stuart
Tue Dec 27, 2016 11:20 am
Brady offline
It looks like the change might not have been applied to all 3 copies of the plug in.
"Nest Home" downloads as 2.0.40 and will not start the plugin.
"Nest Home 2" downloads as 2.0.41 and starts up no problem.
Can you add the correct version of the "Nest Home" 2.0.41?
Thanks for your work on this! Has been an integral part of my home automation :-)
Wed Dec 28, 2016 7:51 pm
Brady offline
Quick update on my previous post. I would not suggest using Nest Home 2 in place of Nest Home 1. The Home 2 version does not include any of the eco mode changes. I went back to Nest Home 1 & simply changed the name of the duplicate action.
Works perfect. Thanks again!!
Thu Dec 29, 2016 5:06 pm
ckeyes888 offline
Just tried upgrading the Nest Home plugin and am getting these errors.
Reloading plugin "NEST Home 2.0.40"
  Starting plugin "NEST Home 2.0.40" (pid 70944)
  NEST Home Error                 Error in plugin execution InitializeMain:
  File "<string>", line 1, in <module>
  File "plugin.py", line 1572, in __init__
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 69, in __init__
  File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 577, in _parseActionsXML
<type 'exceptions.LookupError'>: Duplicate action type id found: fanChangeState
  Stopping plugin "NEST Home 2.0.40" (pid 70944)
  Stopped plugin "NEST Home 2.0.40"
  Error                           plugin "NEST Home 2.0.40" (pid 70944) failed to start -- restarting in 20 seconds
Indigo 6.1.4. 10.6.8
Any help appreciated!
Carl
Thu Dec 29, 2016 7:02 pm
Brady offline
I hope it is ok, but I've attached a working copy of Nest Home 2.0.41. I made 2 changes from the one posted at the top of the thread. Chameleon, once the primary copy is updated I will remove this link. Thanks!
1. In the info.plist I changed <string>2.0.40</string> to <string>2.0.41</string>
2. In Actions.xml I changed the second <CallbackMethod>setFanState</CallbackMethod> to <CallbackMethod>setFanDuration</CallbackMethod>
https://www.dropbox.com/s/crrmtboht8wd2 ... e.zip?dl=0
Thu Dec 29, 2016 8:49 pm
ckeyes888 offline
Tried the Nest Home 2 which loads and works fine but did not find my Protect.
Is there a way to get it added?
Edit: The Protect device I added manually, which for a few hours was not active, decided to become active
and working and located itself in the new Nest Home 2 folder. All seems to be working.
Carl
Sat Dec 31, 2016 8:03 am
Chameleon offline
Hi all and a Happy New Year,
Finally back in the UK and I've now resynced the plugins properly now. You can now download version 2.0.50 for NEST Home, NEST Home 2 and NEST Home 3. I've applied all of the patches to remove the errors that everyone has found. Thanks for all of your patience. You'll find the latest version in the forum.
Thanks again and the new version is nearing release....
Regards
Mike
