Universal Controls Option
Sun Dec 18, 2016 8:53 am
FlyingDiver online
Re: Universal Controls Option
OK, I'm going to have to think on this a bit. And I'll be out most of the day. I might have something later tonight.
Sun Dec 18, 2016 9:51 am
durosity offline
No worries, I appreciate the effort you're taking to look into it!
Sun Dec 18, 2016 11:08 am
I'm a bit unclear about the changes from 7.0 to this. Will it require redefining activities?
Sun Dec 18, 2016 11:49 am
durosity offline
Afaik it only affects any activities you've got set that use the options that have been removed and replaced. I had some device specific ones before that have continued to work.
Sun Dec 18, 2016 12:02 pm
Thanks!!
Let me say again how much I love this plugin. I need to remember to contribute!
Sun Dec 18, 2016 12:08 pm
FlyingDiver online
Device commands should still work the same. Activity commands will need to be redone. That button presses, not Activity start commands.
Sun Dec 18, 2016 12:17 pm
Maybe I'm missing some cool thing I could be doing with my Hub, but I didn't have to redefine activities or change anything about things like "stop" commands.
But the plugin does time out trying to sync hub.
Sun Dec 18, 2016 12:41 pm
durosity offline
I don't recall having to do that for mine. That said I didn't have many so perhaps I did without even realising when I was messing about with the new settings.
Sun Dec 18, 2016 1:24 pm
FlyingDiver online
If you didn't redo them, then that's why the number commands aren't working with the latest version.
I'm spending the day pulling up old smelly carpet at my dad's house, so I won't be able to do any more testing on this until this evening.
Sun Dec 18, 2016 2:06 pm
durosity offline
"If you didn't redo them, then that's why the number commands aren't working with the latest version. "
No that was for other commands like mute. The ones i've been testing with are brand new commands to make sure of no issues like that (i wouldn't wanna send you on a wild goose chase :) )
"I'm spending the day pulling up old smelly carpet at my dad's house, so I won't be able to do any more testing on this until this evening. "
Sounds like fun! When you're finished fancy popping over and helping me with a new corner couch? ;)
Sun Dec 18, 2016 7:54 pm
FlyingDiver online
I think I've got this licked now. https://github.com/FlyingDiver/Indigo-H ... .1.0-beta4
One UI change - the popup for selecting the command is now the uglier "name" field from the hub config data instead of the prettier "label" field. Turns out the label field isn't necessarily unique, while the name field is. And it's the name field that identifies the actual command string to be sent. This change should eliminate an occasional instance of two items in the command popup with identical labels but different names (and commands) that were hidden.
I recommend updating any activity command or device command actions.
Mon Dec 19, 2016 4:40 am
durosity offline
Cool I'll try it out when I get home!
You've done a great job with this plugin, I'll remember it in your annual performance review!
Tue Dec 20, 2016 9:06 pm
FlyingDiver online
Have you had a chance to try the latest beta?
Wed Dec 21, 2016 2:29 am
Woetjes offline
Joe, I have it installed and everything is working fine, no issues detected (yet).
There was suddenly a delay when sending commands to the Hub but after rebooting, everything was fine again.
When I pressed 'volume up' before, the Hub increased the volume by 2 but that's also fixed now.
Thanks again for the work!
Wed Dec 21, 2016 6:12 am
durosity offline
Sorry, been a busy couple of days!
Yep working for numeric commands but not it would seem for GameType Commands. However i'm not too worried about them because i'm gonna have special scripts for selecting X or A or Triangle or whatever depending on whatever console is in use at that time and that uses the "Send Device Command" option.
Only one minor issue seems to be outstanding and that's the error as below whenever you select an option that doesn't work on that command (e.g. the + option when set to use my Sky HD box) but that doesn't affect the use of it!
