Latest Version - 2.0.41 NEST Home 1, 2 & 3 (LOCKED)
Thu Dec 01, 2016 6:40 am
Chameleon offline
Hi all
I've had a number of reports from users regarding errors with NESTHomeXErrors.log files and ECO options.
This upgrade is recommended for all users
NEST Home
https://www.dropbox.com/s/fl0kx7ni5yk9xtj/NEST%20Home.zip?dl=1
NEST Home 2
https://www.dropbox.com/s/jf3vt4yaebwk3w7/NEST%20Home%202.zip?dl=1
NEST Home 3
https://www.dropbox.com/s/u8nrinc36gir6ql/NEST%20Home%203.zip?dl=1
You can install this update in the usual way.
What's new in version 2.0.41?
For users of NEST Home 2.0.40 this update to your version of NEST Home is minor and simply aligns NEST Home with NEST Home 2 and NEST Home 3.
For NEST Home 2 and NEST Home 3 users, this update is especially important due to changes in the way that NEST manages ECO temperatures and if you've recently upgraded to Indigo 7. This version works with both Indigo 6 and 7. The changes are:
1. Bugfix to resolve Log File creation errors and ECO features
If you have any issues resolving this error please contact me with a copy of the error message from the log.
What's next for NEST Home?
I've been working on a whole raft of new functionality for NEST Home that supports the changes that NEST have made to their system and more recently their API.
This includes:
New fields including:
    ECO temperatures
    Locked temperatures
    Is locked?
    Label (you can now name your NEST anything and it can appear in Indigo)
    Location (you can now add a proper location label for your NEST and it will appear in indigo)
    Previous HVAC Mode (so you know what the previous setting was before NEST went into ECO mode)
    Sunlight Correction information (enabled/active)
    Time to Target (estimated time in mins to achieving your target temperature or "training" if you've just installed it
New features including:
    Fan Timer Duration (adds the ability to specify a fan duration in mins from 15,30,45,60,120,240,480 directly from indigo)
    Multiple sites in a single plugin (eliminating the need for NEST Home 2 and NEST Home 3)
New equipment
    NEST Cam (indoor and outdoor) with live video feed and related fields including URLs, Online and Audio Status, Location and Event information
I'm also working on building on the great new features that Matt and Jay have added to Indigo 7 that improve performance and features directly. Some of the new functions listed above will only work properly in Indigo 7 although all of the new fields will be available in the Indigo 6 version. The indigo 7 version will also have multiple sites functionality (different locations or zones in a single plugin) as well as vastly improved performance enhancements. I'll also be looking to work with INDIGOplotD's developer to enhance links and provide better reporting functionality (although I haven't mentioned it to Karl yet but I will - sorry Karl!)
I will support both Indigo 6 & 7 where I can but the use of python 2.7 and the addtional features for Indigo 7 that Matt and Jay have built means that version 7 will always get the better features in the end. It's also where I will concentrate my efforts on integrating NEST Weave in 2017.
Many thanks for all your support
Regards
Mike
Thu Dec 01, 2016 2:36 pm
maslett offline
Re: Latest Version - 2.0.41 for NEST Home, NEST Home 2 & 3
Mike, all the download links appear to point to older versions not 2.0.41. Thanks, Mark
Thu Dec 01, 2016 3:17 pm
Chameleon offline
Try these instead - don't know why they didn't update first time!
Try these:
NEST Home
NEST Home 2
NEST Home 3
Thu Dec 01, 2016 8:31 pm
Ramias offline
Hi Mike
Thanks for doing this.
I'm getting an error below (Duplicate Action id)
thoughts?
Stopping plugin NEST Home (pid 1592)
   NEST Home                       shutdown called
   Stopped plugin NEST Home
   Upgrading plugin NEST Home to newer version 2.0.40 (previous version moved to trash)
   Loading plugin "NEST Home 2.0.40"
   Starting plugin "NEST Home 2.0.40" (pid 96305)
   NEST Home Error                 Duplicate action type id (fanChangeState) found in file Actions.xml
   Stopping plugin "NEST Home 2.0.40" (pid 96305)
   Stopped plugin "NEST Home 2.0.40"
Dec 1, 2016, 9:30:15 PM
   Reloading plugin "NEST Home 2.0.40"
   Starting plugin "NEST Home 2.0.40" (pid 96335)
   Stopping plugin "NEST Home 2.0.40" (pid 96335)
Fri Dec 02, 2016 7:44 pm
asw24b offline
Ramias wrote:
Hi Mike
thoughts?
I am running into the same issue....
Mike
Mon Dec 05, 2016 1:54 am
SHKnapp offline
I'm hitting the same error:
Starting plugin "NEST Home 2.0.40" (pid 47140)
Stopping plugin "NEST Home 2.0.40" (pid 47140)
Trying to install 2.0.41 to see if that's fixed, I can't get it downloaded. The download link for 2.0.41 downloads, but when I try and install it, Indigo says 2.0.40 is already installed
Wed Dec 07, 2016 7:15 pm
jbinder offline
I am getting the exact same error after installing 2.0.41 which reports it is 2.0.40.
Wed Dec 07, 2016 7:21 pm
mvanholstyn offline
I am having the same issue, and mine is reporting 2.0.40 as well.
Thu Dec 08, 2016 5:42 pm
chase offline
Same as everyone else:
Starting plugin "NEST Home 2.0.40" (pid 2366)
Stopping plugin "NEST Home 2.0.40" (pid 2366)
Trying to install 2.0.41 to see if that's fixed, I can't get it downloaded. The download link for 2.0.41 downloads, but it is installed as 2.0.40
Fri Dec 09, 2016 5:14 am
jstoub offline
Also getting these same errors. Plugin updates as v2.0.40. And now state is set to plugin stopped and I can't get it to work anymore.
Any suggestions?
Indigo 7
Fri Dec 09, 2016 8:14 am
Woetjes offline
There is a duplication action id in the Actions xml (fanChangeState).
I disabled the plugin, rename the "fanChangeState" to something else (fanDuration) and enabled it again. It's working for me as I'm only using the Nest Protects.
This change will probably have an impact on the Nest Thermostat that are using the fan duration...
Sat Dec 10, 2016 11:08 am
jbinder offline
Pardon my ignorance. Where is actions xml located?
Sat Dec 10, 2016 11:45 am
ryanbuckner offline
1. Disable the plugin
2. Navigate to Indigo 7 > Plugins (Disabled) > Nest Home *
3. Right Click on Nest Home and click on Show Package Contents
4) Edit the Actions.xml file as noted in the response above by Woetjes
* Note that I took the screenshot after I re-enabled the plugin so the folder is different
Sat Dec 10, 2016 12:10 pm
ryanbuckner offline
Any suggestions?
Indigo 7
Info.plist still has the version listed as 2.0.40. Change it to 2.0.41 and it will install
Sun Dec 11, 2016 10:18 am
ryanbuckner offline
Still getting this error too:
Dec 11, 2016, 10:36:36 AM
   NEST Home Error                 versionCheck: There was an error parsing the server's version file.
