Roomba 980 Scripts
Fri Nov 25, 2016 10:37 pm
Bollar offline
Roomba 980 Scripts
My Black Friday find was a Roomba 980. It's been years since I last had one and I'm impressed by how well this one works! The optical sensor lets it get to any room in the house and in a few cycles, it can clean everything without a lot of repetition.
I have found that it's WiFi connected and someone has hacked a javascript library to control it. https://github.com/koalazak/dorita980
I'm sure in a couple of days, I can cobble together a couple of scripts to have Roomba start cleaning when we leave the house and stop when we get home. But I thought I'd ask if anyone else has given this a shot so I don't have to recreate something that already exists.
Sat Nov 26, 2016 6:38 pm
Bollar offline
Re: Roomba 980 Scripts
I've made some progress and I can authenticate locally to the Roomba with this code:
import requests
from base64 import b64encode
from requests.auth import HTTPBasicAuth
from requests.utils import quote
roombaIP = (indigo.variables['roombaIP'].value)
roombaPassword = (indigo.variables['roombaPassword'].value)
roombaBlid = (indigo.variables['roombaUsernameBlid'].value)
passEncode = b64encode('user:'+roombaPassword)
post_url = 'https://' + roombaIP + ':443/umi'
#post_url = 'https://irobot.axeda.com:443/services/v1/rest/Scripto/execute/AspenApiRequest'
head = {
'User-Agent': 'aspen%20production/2618 CFNetwork/758.3.15 Darwin/15.4.0',
'Authorization': 'Basic ' + passEncode,
'ASSET_ID': 'ElPaso@irobot!' + roombaBlid
payload = {
'blid': roombaBlid,
'robotpwd': roombaPassword,
'do': 'get',
#'method': 'multipleFieldSet&value=%7B%0A%20%20%22remoteCommand%22%20:%20%22$' + 'getStatus' + '%22%0A%7D',
'args': ['time'],
'id': '101'
r = requests.post(post_url, data=payload, headers=head, verify=False)
indigo.server.log(str(r))
indigo.server.log(str(r.status_code))
indigo.server.log(str(r.headers))
indigo.server.log(str(r.raw))
indigo.server.log(str(r.text))
Unfortunately, I haven't figured out how to parse the payload. If any of you are json-adept and can decode what the original author did, that would be super helpful to me.
Sat Nov 26, 2016 6:44 pm
Bollar offline
Here's the relevant section from the original code:
function apiCall (method, command, args) {
+    rid++;
+    if (rid > 1000) rid = 1;
+    requestOptions.body = '{"do":"' + method + '","args":["' + command + '"' + (args ? ', ' + JSON.stringify(args) : '') + '],"id":' + rid + '}';
+    return request(requestOptions).then(JSON.parse);
+  return {
+    getTime: () => apiCall('get', 'time'),
+    getBbrun: () => apiCall('get', 'bbrun'),
+    start: () => apiCall('set', 'cmd', {'op': 'start'}),
+    pause: () => apiCall('set', 'cmd', {'op': 'pause'}),
+    stop: () => apiCall('set', 'cmd', {'op': 'stop'}),
+    resume: () => apiCall('set', 'cmd', {'op': 'resume'}),
+    dock: () => apiCall('set', 'cmd', {'op': 'dock'}),
Sun Nov 27, 2016 10:40 am
Bollar offline
I know more about javascript than I ever wanted to know.
Success. This code gets the time from the Roomba. A bit more digging and I'll have the other commands I care about.
import requests
import json
head = {
payload = {
"do": "get",
"args": ["time"],
"id": "1"
r = requests.post(post_url, json=payload, headers=head, verify=False)
broken = str(r.text)
fixed = broken.replace('"''}','')
data = json.loads(fixed)
indigo.variable.updateValue('roombaD', value=str(data['ok']['d']))
if data['ok']['m'] < 10:
   indigo.variable.updateValue('roombaTime', value=(str(data['ok']['h']) + ':0' + str(data['ok']['m'])))
   indigo.variable.updateValue('roombaTime', value=(str(data['ok']['h']) + ':' + str(data['ok']['m'])))
And the log:
   Script                          {'do': 'get', 'args': ['time'], 'id': '1'}
   Script                          <Response [200]>
   Script                          https://10.0.1.91:443/umi
   Script                          <bound method Response.json of <Response [200]>>
   Script                          200
   Script                          {'Transfer-Encoding': 'chunked', 'Connection': 'close', 'Content-Type': 'application/json', 'Server': 'Marvell-WM'}
   Script                          <requests.packages.urllib3.response.HTTPResponse object at 0x110d28250>
   Script                          {"ok":{"d":"sun","h":10,"m":7},"id":1"}}
Sun Nov 27, 2016 8:08 pm
loafbread offline
I look forward to trying this as soon as I get my blid. I assume the only way to do that is to do the 'npm run getpassword IPaddress' from the GitHub repository?
Sun Nov 27, 2016 8:17 pm
Bollar offline
Yes.
I could probably replicate his code, but since I only needed to do it once, my motivation was very low.
I'm still trying to sort out the malformed JSON output so I can read the robot's status.
viewtopic.php?f=107&t=17302
Sun Nov 27, 2016 10:18 pm
Bollar offline
Here's the "Mission Status" script. It gives all of the current information from the Roomba, including the polar coordinates from the base - I'm sure someone bored enough could plug that into one of the other Indigo PlugIns to map the robot's progress.
You'll need to create all of the variables.
import requests
import json
head = {
payload = {
"do": "get",
"args": ["mssn"],
"id": "1"
indigo.variable.updateValue('roombaFlags', value=str(data['ok']['flags']))
indigo.variable.updateValue('roombaCycle', value=str(data['ok']['cycle']))
indigo.variable.updateValue('roombaPhase', value=str(data['ok']['phase']))
indigo.variable.updateValue('roombaTheta', value=str(data['ok']['pos']['theta']))
indigo.variable.updateValue('roombaX', value=str(data['ok']['pos']['point']['x']))
indigo.variable.updateValue('roombaY', value=str(data['ok']['pos']['point']['y']))
indigo.variable.updateValue('roombaBatPct', value=str(data['ok']['batPct']))
indigo.variable.updateValue('roombaExpireM', value=str(data['ok']['expireM']))
indigo.variable.updateValue('roombaRechrgM', value=str(data['ok']['rechrgM']))
indigo.variable.updateValue('roombaError', value=str(data['ok']['error']))
indigo.variable.updateValue('roombaNotReady', value=str(data['ok']['notReady']))
indigo.variable.updateValue('roombaMssnM', value=str(data['ok']['mssnM']))
indigo.variable.updateValue('roombaSqFt', value=str(data['ok']['sqft']))
indigo.variable.updateValue('roombaID', value=str(data['id']))
Sun Nov 27, 2016 10:26 pm
Bollar offline
Revised version of Get Time:
import requests
import json
head = {
payload = {
"do": "get",
"args": ["time"],
"id": "1"
Sun Nov 27, 2016 10:50 pm
Bollar offline
The Start script - also works for dock, pause, stop & resume.
import requests
import json
head = {
payload = {
"do": "set",
# You can replace start with dock, pause, stop & resume
"args": ["cmd", {"op":"start"}],
"id": "1"
r = requests.post(post_url, data=json.dumps(payload), headers=head, verify=False)
data = json.loads(fixed).
Mon Nov 28, 2016 3:11 pm
Bollar offline
import requests
import json
head = {
payload = {
"do": "get",
"args": ["time"],
"id": "1"
Mon Nov 28, 2016 3:49 pm
FYI - I have a Roomba 980 on order, it'll be here in a couple days.
If it's OK with you, I'll roll these scripts into an actual plugin.
Mon Nov 28, 2016 3:50 pm
Bollar offline
That would be awesome!
Mon Nov 28, 2016 3:53 pm
Bollar offline
I achieved nirvana today. My better half went out during the day and while she was out, Roomba did some cleaning. I had it start a cycle a minute after she armed the security system and I had it dock as soon as Geofency reported she was near home. It completed docking about 10 seconds after she disarmed the alarm -- if I set that geofence just a bit larger, she won't even notice it ran.
Next on my list is to decode the status messages so I can report when the bin needs emptying.
Mon Nov 28, 2016 4:33 pm
Bollar offline
It was a bit easier than I thought to get the credentials. See the following message.
Mon Nov 28, 2016 6:26 pm
Bollar offline
This script gets the credentials that allows the other scripts to run. You need to know the Roomba's IP address and create the roombaIP variable. The author of dorita980 made a big deal about making sure the headers were right, but I haven't found the Roomba to be sensitive to the headers at all.
To get Roomba into the proper mode, Roomba must be in the dock. Hold down the "Home" button until Roomba plays a four note confirmation sound. Then run this script. There's no error checking, so if you get the timing wrong, you may need to execute again. If the script fails, you'll need to put Roomba back into this mode again.
import requests
import json
#roombaPassword = (indigo.variables['roombaPassword'].value)
#roombaBlid = (indigo.variables['roombaUsernameBlid'].value)
head = {
payload = {
"do": "get",
"args": ["passwd"],
"id": "1"
fixed = broken.replace('"''}}','}')
pwd = str(data['ok']['passwd'])
indigo.server.log('Password: ' + pwd)
passEncode = b64encode('user:'+ pwd)
head = {
payload = {
"do": "get",
"args": ["sys"],
"id": "1"
blid = ''
for element in data['ok']['blid']:
   blidA = hex(element)
   blidB = blidA.replace('0x','')
   blidC = blidB.upper()
   blid += str(blidC)
indigo.server.log('Blid: ' + blid)
#indigo.variable.updateValue('roombaPassword', value=str(pwd))
#indigo.variable.updateValue('roombaUsernameBlid', value=str(blid))
