2016-11-25 08:12:32.640 MyQ Debug actionControlDevice: "Range Rover" Unlock
2016-11-25 08:12:32.643 MyQ Debug changeDevice: Range Rover, state = 1
2016-11-25 08:12:32.835 MyQ Debug myqLogin: response = <Response [200]>
2016-11-25 08:12:32.838 MyQ Debug myqLogin: content = {"UserId":0,"SecurityToken":"xxx","ReturnCode":"0","ErrorMessage":"","BrandId":2,"BrandName":"Chamberlain","RegionId":1}
2016-11-25 08:12:32.840 MyQ Debug myqLogin: Success, Brand = Chamberlain, SecurityToken = xxx
2016-11-25 08:12:33.025 MyQ Debug changeDevice: Bad return code: MyQ Application ID unrecognized. (1001)
2016-11-25 08:13:30.993 MyQ Debug actionControlDevice: "Tesla" Lock
2016-11-25 08:13:30.995 MyQ Debug changeDevice: Tesla, state = 0
2016-11-25 08:13:31.230 MyQ Debug myqLogin: response = <Response [200]>
2016-11-25 08:13:31.233 MyQ Debug myqLogin: content = {"UserId":0,"SecurityToken":"xxx","ReturnCode":"0","ErrorMessage":"","BrandId":2,"BrandName":"Chamberlain","RegionId":1}
2016-11-25 08:13:31.236 MyQ Debug myqLogin: Success, Brand = Chamberlain, SecurityToken = xxx
2016-11-25 08:13:31.445 MyQ Debug changeDevice: Bad return code: MyQ Application ID unrecognized. (1001)
FlyingDiver wrote:That's odd. Grab this version:
Bollar wrote:That works. I was using 7.1 and didn't notice if there was a v4 in that version.
Bollar wrote:Also, I don't know if this is important or not, but the Device Details: Last Update doesn't change when I Send Status Request. I see it's successful in the log.
FlyingDiver wrote:Bollar wrote:Also, I don't know if this is important or not, but the Device Details: Last Update doesn't change when I Send Status Request. I see it's successful in the log.
I don't explicitly set that in the plugin. I think the Indigo server does, based on actual changes to the device state. Are you saying that the door states did change but the Last Update did not?
Bollar wrote:Sorry, when I manually send a status request (not when I open or close a door), the last update time doesn't update. IMO, it should.
FlyingDiver wrote:Bollar wrote:Sorry, when I manually send a status request (not when I open or close a door), the last update time doesn't update. IMO, it should.
Well, I'm writing the current door states back to the Indigo server on every status report or check. If the update time isn't changing, it's because Indigo isn't doing so when the states haven't actually changed. I think you 're going to need to do a feature request to Matt & Jay to change that.
Nov 27, 2016, 3:52:03 PM
MyQ Debug myqLogin: content = {"UserId":0,"SecurityToken":"71836042...","ReturnCode":"0","ErrorMessage":"","BrandId":1,"BrandName":"Liftmaster","RegionId":1}
MyQ Debug myqLogin: Success, Brand = Liftmaster, SecurityToken = 71836042...
MyQ Debug getDevices: 3 Devices
MyQ Debug getDevices: MyQDeviceTypeId = 1, DeviceId = 50360411
MyQ Debug getDevices: MyQDeviceTypeId = 7, DeviceId = 251758172
MyQ Error getDevices: Opener North Door (251758172), state out of range: 9
MyQ MyQ Device North Door is now Unknown
MyQ Debug getDevices: MyQDeviceTypeId = 7, DeviceId = 251758173
MyQ Error getDevices: Opener South Door (251758173), state out of range: 9
MyQ MyQ Device South Door is now Unknown
Nov 27, 2016, 4:02:37 PM
MyQ Debug myqLogin: content = {"UserId":0,"SecurityToken":"a4574d3f...","ReturnCode":"0","ErrorMessage":"","BrandId":1,"BrandName":"Liftmaster","RegionId":1}
MyQ Debug myqLogin: Success, Brand = Liftmaster, SecurityToken = a4574d3f...
MyQ Error getDevices: Opener North Door (251758172), state out of range: 8
MyQ Error getDevices: Opener South Door (251758173), state out of range: 8
Nov 27, 2016, 4:13:10 PM
MyQ Debug myqLogin: content = {"UserId":0,"SecurityToken":"8f6dd356...","ReturnCode":"0","ErrorMessage":"","BrandId":1,"BrandName":"Liftmaster","RegionId":1}
MyQ Debug myqLogin: Success, Brand = Liftmaster, SecurityToken = 8f6dd356...
doorStateNames = ["Unknown", "Open", "Closed", "Stopped", "Opening", "Closing", "Unknown", "Disconnected"]
Nov 27, 2016, 5:29:45 PM
MyQ Debug myqLogin: content = {"UserId":0,"SecurityToken":"a861a310...","ReturnCode":"0","ErrorMessage":"","BrandId":1,"BrandName":"Liftmaster","RegionId":1}
MyQ Debug myqLogin: Success, Brand = Liftmaster, SecurityToken = a861a310...
MyQ Debug getDevices: Opener South Door (251758173), state = 2
