Heatmiser Neo Plugin
Mon Nov 21, 2016 4:23 pm
racarter offline
Probably only of interest to UK/European users, but I've written a plugin for the Heatmiser Neo range of thermostats; here's a link:
https://www.indigodomo.com/library/399/
Sat Jan 28, 2017 7:02 pm
speaksgeek offline
Re: Heatmiser Neo Plugin
I'd certainly be keen to try it out.
I'm in Australia, and have the app working as supplied by heatmiser, but keen to try out your plugin for indigo.
Sun Jan 29, 2017 3:15 am
racarter offline
@speaksgeek
Just PM me your email address and I'll send you the plugin to try.
Alan
Sun Jan 29, 2017 3:23 pm
colinpartridge offline
Would this plugin work with the earlier heatmiser wi-fi stat, the PRT-TS WiFi ?
Sun Jan 29, 2017 4:43 pm
racarter offline
@colinpartridge
I'm afraid not - the protocol is completely different.
I wrote a plugin for the WiFi model when I had a Vera home automation system, but by the time I moved over to Indigo I'd changed to the Neo so didn't rewrite the WiFi plugin.
Mon Jan 30, 2017 2:16 am
racarter wrote:
@colinpartridge
thats a pity, but not surprising.
Cheers
Colin
Thu Mar 23, 2017 5:28 am
Colly offline
Hi racarter,
I'm getting the opportunity to upgrade my Heatmiser system to Neo at a really good discount! Is there anything that I need to know before doing so from a hardware perspective of what I need or don't need for your plugin to work?
Thu Mar 23, 2017 8:02 am
racarter offline
Hi Colly
The plugin communicates with the Neohub, so as long as your thermostats are connected to the hub you should be OK.
Alan
Thu Mar 23, 2017 8:27 am
Colly offline
Perfect Alan. Looking forward to trying it out. Have you got it uploaded anywhere that I can download? It will probably be a few weeks at least before I get my system updated so no hurry.
Thu Mar 23, 2017 4:19 pm
racarter offline
Just drop me a PM with your email address when you're ready and I'll send you a copy.
Mon Feb 26, 2018 1:56 pm
siclark offline
For anyone else using this with electric floors, I've just discovered that using the masquerade and virtual energy device plugins gives you an energy device to track electricity usage with.
Mon Aug 06, 2018 10:09 am
Wizard Sleeve offline
Hi
Not sure this is the right place but...
I've started getting errors with the Heatmiser Neo Plugin today.
Namely this....
Heatmiser-Neo Starting Heatmiser Neo monitoring thread
Heatmiser-Neo Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 100, in runConcurrentThread
File "plugin.py", line 382, in updateEng
KeyError: u'Studio Lounge Thermostat'
Heatmiser-Neo Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Every 10 seconds. It still seems to be working fine. The change I've made today is to upgrade to Homebridge Kit from buddy and then add the thermostats on to the home bridge. Temps seem right both on indigo and on the Home App. Not sure whats happening.
Any thoughts
Lee
Mon Aug 06, 2018 11:12 am
siclark offline
Have you restarted both Heatmiser and Homekit plugins?
I sometimes get this on random plugins when I'm missing around with settings. A restart usually solves it.
Mon Aug 06, 2018 1:12 pm
racarter offline
If you're still having issues with this I suggest you go into the plugin config, enable 'Copy Neo comms to Indigo Event Log' then send the results to me via the Help link (click 'About'), or here.
Sun Dec 02, 2018 3:48 pm
siclark offline
If anyone is using grafana, I've created a generic ish dashboard for Heatmiser, posted on the Grafana board
