FlyingDiver wrote:Wondercow wrote:FlyingDiver wrote:Since Indigo 7 uses Python 2.7, which is the osX default. "sudu pip install sleekxmpp" should be what you need to run for the install.
I tried the above (using su
do, I recognize that, at least
) and I got "pip: command not found"
That's what I get posting from my iPad.
Try this:
- Code: Select all
sudo easy_install pip
sudo pip install sleekxmpp
I tried this and get
Mac-Pro:~ MacPro$ sudo pip install sleekxmpp
The directory '/Users/MacPro/Library/Caches/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/Users/MacPro/Library/Caches/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Requirement already satisfied: sleekxmpp in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
I can't get the plugin to start. Anyone have any ideas?
