Remote access without Prism?
Wed Nov 16, 2016 10:48 pm
wi_pedaler offline
If I know my IP address, can I configure Indigo Touch to connect with Indigo without the Prism service?
Currently running Indigo 6 Pro.
Wed Nov 16, 2016 10:59 pm
Bollar offline
Re: Remote access without Prism?
Yes. You'll probably need to set up port following on your router to forward port 8176 to your Indigo server's internal address.
Also, you should know that traffic sent directly to Indigo is not encrypted. if that's a concern, then Prism is the easiest alternative. (Running your own VPN is a somewhat more difficult alternative.)
Thu Nov 17, 2016 8:20 am
I did this for quite a while, and in fact I'm still doing it in some cases on some devices.
I highly recommend something like dyndns or No-IP.com unless your ISP gives you a static IP address.
