Upgrading to NodeJS version 6
Fri Sep 30, 2016 10:30 am
webdeck offline
The latest version of homebridge added support for cameras that use the RTSP protocol. But it also required using NodeJS version 6 instead of version 4. So, you will get errors if you try to upgrade to the latest version of homebridge, unless you upgrade to NodeJS 6.
If you followed my installation instructions, then here is how to upgrade:
sudo port uninstall npm2
sudo port uninstall nodejs4
sudo rm -fr /opt/local/lib/node_modules/
sudo port install nodejs6
sudo port install npm3
sudo npm install -g homebridge
sudo npm install -g homebridge-indigo
If you installed any other homebridge plugins, you would need to reinstall those as well.
Finally, you need to restart your homebridge.
-Mike
Fri Sep 30, 2016 1:29 pm
durosity offline
Re: Upgrading to NodeJS version 6
That's pretty cool. If only there was a package to pull securityspy feeds through to it :D
Tue Oct 18, 2016 10:16 am
Umtauscher offline
Hi, unfortuately the upgrade broke my installation:
Everything installed without errors. Now when I start homebridge, it terminates with the following error:
[18.10.2016, 18:12:29] [My Indigo Server] Indigo request: http://127.0.0.1:8176/devices/Fenster%2 ... ature.json
/opt/local/lib/node_modules/homebridge-harmonyhub/node_modules/harmonyhubjs-client/lib/login/hub.js:59
if (response.identity && response.identity !== undefined) {
TypeError: Cannot read property 'identity' of undefined
Any ideas?
TIA
Wilhelm
Tue Oct 18, 2016 10:19 am
Umtauscher offline
Sorry - seems to be a problem with the homebridge-harmonyhub plugin.
When I disable that, my indigo goes through.
Still hoping for ideas....
Fri Nov 11, 2016 2:51 pm
Following your instructions I see
2doghill:Documents macadmin$ sudo npm install -g homebridge
/opt/local/bin/homebridge -> /opt/local/lib/node_modules/homebridge/bin/homebridge
> mdns@2.3.3 install /opt/local/lib/node_modules/homebridge/node_modules/mdns
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/Users/macadmin/.node-gyp/6.9.1"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/local/lib/node_modules/homebridge/node_modules/mdns/.node-gyp"
Is this anything I should worry about? Homebridge started properly after the installs and is running.
Fri Nov 11, 2016 3:07 pm
Here's what you have to do if you don't normally mess with ports, npm, or nodejs. Like if you haven't touched it since you first installed homebridge. Like me.
There are many steps, and the responses you get from attempting don't mention things you might not know, like how all the commands require sudo.
I'm attaching it here because it's a lot.
npm update.txt
(22.37 KiB) Downloaded 277 times
Fri Nov 11, 2016 11:09 pm
webdeck offline
> node-gyp rebuild
It is safe to ignore that warning.
-Mike
Sun Dec 11, 2016 8:11 pm
dnomode offline
I tried to upgrade and got the following after running sudo port install nodejs6:
Edmonds-Mac-mini:~ edmond$ sudo port install nodejs6
--->  Computing dependencies for nodejs6
--->  Installing nodejs6 @6.9.1_0
Error: org.macports.install for port nodejs6 returned: no destroot found at: /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_devel_nodejs6/nodejs6/work/destroot
Please see the log file for port nodejs6 for details:
    /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_devel_nodejs6/nodejs6/main.log
To report a bug, follow the instructions in the guide:
    http://guide.macports.org/#project.tickets
Error: Processing of port nodejs6 failed
What should I do?
Edmond
Sun Dec 11, 2016 8:28 pm
Colorado4Wheeler offline
Did you uninstall everything first?
Sun Dec 11, 2016 8:36 pm
dnomode offline
I had it running before with Indigo 6. Just undated to Indigo 7 a couple of weeks ago and tried to use Siri today and noticed that it was not working any longer. So I tried to the update. I uninstalled npm2 and nodejs4, then ran sudo rm -fr /opt/local/lib/node_modules/ without any error message until trying to run sudo port install nodejs6. What you think?
Mon Dec 12, 2016 12:07 am
MarcoGT offline
I had the same problem.
Try the following:
sudo port -v selfupdate
If it doesn't help, try:
sudo port clean <name_of_the_port> (for example, nodejs)
Mon Dec 12, 2016 5:55 pm
dnomode offline
Try the following:
Thanks for your help. That kind of worked. Now my system lets me run the below with no errors:
However I get the following error when trying the next step:
Edmonds-Mac-mini:~ edmond$ sudo port install npm3
--->  Computing dependencies for npm3
--->  Fetching archive for npm3
--->  Attempting to fetch npm3-3.10.9_0.darwin_12.noarch.tbz2 from https://packages.macports.org/npm3
--->  Attempting to fetch npm3-3.10.9_0.darwin_12.noarch.tbz2.rmd160 from https://packages.macports.org/npm3
--->  Installing npm3 @3.10.9_0
--->  Activating npm3 @3.10.9_0
Error: org.macports.activate for port npm3 returned: Image error: /opt/local/bin/npm is being used by the active npm port.  Please deactivate this port first, or use 'port -f activate npm3' to force the activation.
Please see the log file for port npm3 for details:
    /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_devel_npm3/npm3/main.log
Error: Processing of port npm3 failed
What should I try next?
Edmond
Mon Dec 12, 2016 6:06 pm
The entire upgrade process is built on uninstalling EVERYTHING first, then reinstalling it to get NodeJS 6. I would just start from scratch and uninstall everything - and watch the messages, it may complain when you try to uninstall that you didn't specify which version - this means you likely have TWO versions and each one will need to be uninstalled using something like "npm uninstall npm @ 10.1.33", etc.
Mon Dec 12, 2016 6:24 pm
dnomode offline
So, do I just need to uninstall npm or is there more to it?
Mon Dec 12, 2016 9:26 pm
Look at the first post in this thread, you need to uninstall everything.
