Hue Lights - Free Philips Hue Plugin
Sat Nov 21, 2015 2:23 pm
nsheldon offline
Re: Hue Lights - Free Philips Hue Plugin
Version 1.3.15 Posted
  • Updated supported device list by moving it into a separate Python file for easier maintenance
  • Added support for the Hue White A19 extension bulb.
Thu Dec 24, 2015 1:15 am
nsheldon offline
Version 1.3.16 Posted
  • Added support for the Phoenix wall light.
Note that the Phoenix light will appear in the Hue bulb list. This means that the plugin will allow HSB or XY (RGB) color commands to be sent to the Phoenix even though the Phoenix does not support such commands. This will generate an error from the Hue hub (and in the plugin). Fuller support for color-temperature-only lights will require more significant changes to the plugin code later on.
Fri Dec 25, 2015 4:37 am
nsheldon offline
Version 1.3.17 Posted
  • Updated Phoenix support so it appears in the LivingWhites device list instead of the color Hue bulbs list.
Sun Apr 24, 2016 1:12 am
nsheldon offline
Version 1.3.18 Posted
  • Fixed incompatibility with Indigo 6.1.8 that caused every HTTP connection to the Hue hub to generate a "Starting new HTTP connection (1)..." entry in the Indigo log.
Fri Apr 29, 2016 3:38 am
nsheldon offline
Version 1.3.19 Posted
  • Added support for new Phoenix light model.
Fri May 13, 2016 12:39 am
nsheldon offline
Version 1.3.20 Posted
  • Fixed the pairing process to work with hub firmware versions released on or after April 2016.
  • Simplified hub pairing process (much less complicated now).
  • Improved plugin configuration window error checking.
Fri May 27, 2016 12:09 pm
nsheldon offline
Version 1.3.21 Posted
  • Added support for the Osram Lightify CLA60 Tunable White bulb.
Mon Jun 06, 2016 5:56 pm
nsheldon offline
Version 1.3.22 Posted
  • Fixed error when attempting to obtain device status from Osram CLA60 lights. Light now appears as a Living Whites bulb.
  • Improved light status gathering method to prevent plugin crashes if a light device doesn't have an expected property.
Mon Jul 04, 2016 4:26 am
nsheldon offline
Version 1.3.23 Posted
  • Added ability to use an Indigo variable for the ramp rate in all actions that have a ramp rate parameter.
  • Added ability to use Indigo variables and other Indigo dimmers as the brightness source in actions that have a 0 to 100 percent scale brightness parameter (i.e. the "Set Hue/Saturation/Brightness" and "Set Color Temperature" actions. The "Set Brightness with Ramp Rate" action already had this capability).
  • Added ability to use an Indigo variable for color temperature in the "Set Color Temperature" action.
Wed Jul 13, 2016 1:29 am
nsheldon offline
Version 1.3.24 Posted
  • Fixed a bug that caused the plugin to hang then crash after adding a Hue Group device.
Sat Jul 23, 2016 6:53 pm
nsheldon offline
Version 1.3.25 Posted
  • Added support for 2 Hue White Ambiance bulb models.
  • Fixed bug that caused the plugin to crash if a light had no color information from the Hue hub.
Sun Jul 24, 2016 8:58 pm
nsheldon offline
Version 1.3.26 Posted
  • Actually added the 2nd Hue White Ambiance model ID this time.
Mon Aug 22, 2016 2:23 am
nsheldon offline
Version 1.3.27 Posted
  • Fixed (hopefully) a bug that caused the plugin to crash when updating a bulb that doesn’t support the hue/saturation feature.
Mon Oct 24, 2016 12:27 am
nsheldon offline
Version 1.3.28 Posted
  • Added support for the Hue bulb v3, Hue White v2 and Hue White v3.
Fri Nov 04, 2016 2:04 am
nsheldon offline
Version 1.3.29 Posted
  • Added support for additional Hue light models.
Page 5 of 13 1, 2, 3, 4, 5, 6, 7, 8 ... 13
