Can't get Homebridge to auto-load
Fri Oct 14, 2016 8:51 am
Colorado4Wheeler offline
Re: Can't get Homebridge to auto-load
This should be resolved soon, a plugin that manages HB will be released in the very near future, and some changes that Webdeck has made should make it possible to not only handle the installation in the plugin but to also support multiple instances of HB on a single computer to help with the 99 device limit (these last two parts currently in development, should be ready by the plugin launch).
Fri Oct 14, 2016 10:46 am
durosity offline
Awesome! I've just started bumping against the 99 device limit.. i had to sacrifice being able to tell siri to turn on the extractor fan in the utility room that i never, ever use. Frankly.. this is unacceptable.
Thu Nov 10, 2016 7:17 am
HB still crashes for me 2-3 times a day.
Last log entry was probably after a computer restart 2 days ago
path.js:8
    throw new TypeError('Path must be a string. Received ' +
TypeError: Path must be a string. Received undefined
    at assertPath (path.js:8:11)
    at Object.posix.join (path.js:479:5)
    at Function.User.storagePath (/opt/local/lib/node_modules/homebridge/lib/user.js:30:15)
    at Function.User.persistPath (/opt/local/lib/node_modules/homebridge/lib/user.js:38:25)
    at module.exports (/opt/local/lib/node_modules/homebridge/lib/cli.js:24:17)
    at Object.<anonymous> (/opt/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    at Module._compile (module.js:409:26)
    at Object.Module._extensions..js (module.js:416:10)
    at Module.load (module.js:343:32)
    at Function.Module._load (module.js:300:12)
I've restarted it manually many times.
On a similar note, I've tried to create a workaround where I have an action group that does
do shell script "/Users/macadmin/Documents/homebridgeStart.sh"
and even though I can manually do
./homebridge.sh
at the command line and it starts up fine, I can't make the action group work. No errors in Indigo, but no result either.
