Can't Generate API Key
Fri Oct 07, 2016 2:17 am
Mayhem offline
I have a reoccurring issue where after a while I can't set the temperature. I adjust the set point but at the next poll it reverts back to original setting.
No worries I found out that a new API key sorted this out.
How ever it has happened again and now I can't find the page to generate a key and the assist button on the plug in does not appear to work.
I think Amazon has put the Echo and nest development together?? Is this why I can't find it?
Any assistance would be much appreciated.
Cheers
Neil
Fri Oct 07, 2016 2:47 pm
Mayhem offline
Re: Can't Generate API Key
Ok so found out how to generate a pin by having to register a bogus app development which then give a url that then you can get a pin.
I entered the pin to the plugin but it wouldn't take it.
Went through the exercise again and the next pin worked.
Anyone else having the same issue?
Sat Oct 08, 2016 3:10 am
Mayhem offline
OK so disregard any of the above post.....
I have found the issue...... And it was me....
Sorry. :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
Users browsing this forum: No registered users and 20 guests
