Harmony Hub plugin
Sat Sep 17, 2016 3:49 pm
Re: Harmony Hub plugin
Baby steps.
I get this in the Indigo log
 Indigo Cocoa client connected
  Reloading plugin "Harmony Hub 0.2.8"
  Starting plugin "Harmony Hub 0.2.8" (pid 13716)
  Harmony Hub Error               Error in plugin execution InitializeMain:
  File "plugin.py", line 8, in <module>
ImportError: No module named sleekxmpp
  Stopping plugin "Harmony Hub 0.2.8" (pid 13716)
  Stopped plugin "Harmony Hub 0.2.8"
though I did this:
Office-Mini:~ macadmin$ sudo -H  pip install sleekxmpp
Collecting sleekxmpp
  Downloading sleekxmpp-1.3.1.tar.gz (831kB)
    100% |████████████████████████████████| 839kB 484kB/s
Installing collected packages: sleekxmpp
  Running setup.py install for sleekxmpp ... done
Successfully installed sleekxmpp-1.3.1
Sat Sep 17, 2016 4:42 pm
You're probably installing the package for Python 2.7, which is the default. You need to install it for Python 2.6. You need to install pip-2.6 (or is it pip2.6), then use it to install the package.
I know this was discussed somewhere in this ungodly long thread.
Sat Sep 17, 2016 4:55 pm
OK, I figured it out.
For those following in the future:
Go here. Read. http://stackoverflow.com/questions/2429 ... python-2-6
Assuming it downloads to Downloads then:
Office-Mini:~ macadmin$ cd ~/Downloads/
Office-Mini:Downloads macadmin$ sudo python2.6 get-pip.py
There will be many results in terminal, and warnings about deprecations.
Office-Mini:Downloads macadmin$ sudo pip2.6 install requests
Ditto about deprecation warnings.
Office-Mini:Downloads macadmin$ sudo pip2.6 install sleekxmpp
Ditto ditto.
Disable and reload the Harmony Hub plugin in Indigo. Check the log for errors.
You should be golden.
Sat Sep 17, 2016 5:26 pm
And on to confusion about the functioning plugin!
Created the device, logged in, getting statuses of what's happening.
But I don't see a way to have any thing beyond ANY activity change be a trigger for Indigo. And I don't understand the proper choice to make in sub menus when creating an Action Group to send an activity. Is the attached right?
Screen Shot 2016-09-17 at 7.24.58 PM.png (16.47 KiB) Viewed 4470 times
Sat Sep 17, 2016 6:21 pm
The only thing that the hub broadcasts are activity messages, basically. There's AV activities and HA activities. So you can set up actions based on what Activity the hub has started (or ended).
I don't have enough info about the HA activity type messages to implement usable actions for them. If you want your Hub to control Indigo devices, use my LIFX Bridge plugin to create pseudo-devices (real devices or action groups) that appear (to the Hub) to be LIFX devices. Then you can add them to activities defined for the Hub.
As for creating Indigo actions to send through the Hub, you've got it right. You're basically selecting a command that the Hub knows for a specific activity or device. Like if you were assigning a command to a button on the remote.
Sat Sep 17, 2016 8:04 pm
I don't want my hub to control anything beyond my AV. But I don't understand how to tell the hub to start an activity. I'm also missing how to use the Hub's activity as a trigger.
Glad to know I've got it right, but again, I don't understand what the Command Group and Command options represent. As I attempted to configure it in the screen shot, it did not work. All I wanted was to make the top level activity start.
Sat Sep 17, 2016 8:27 pm
To start an Activity from Indigo, create an action (group, trigger, whatever) that does "Device Actions -> Harmony Hub Controls -> Start Activity". Select the Hub you're commanding, then the Activity name.
To trigger on an Activity change, it's a "Harmony Hub Event". You probably want "Activity Finished Notification", then do a condition based on the currentActivityName (or number) state value.
Command Group and Command are if you want to send keypresses to your devices. Like Pause when the doorbell rings. :)
Sun Sep 18, 2016 6:42 am
Trouble is, my attempt to set up changing an activity won't let me set it up without also specifying a command group and command.
Sun Sep 18, 2016 7:12 am
You want to use "Start Activity", not "Send Activity Command". The first tells the Hub to run the sequence to activate a specific Activity. The latter is for sending a command (keypress) associated with the running Activity.
Sun Sep 18, 2016 9:06 am
Duh. I had blasted right past that selection.
Thank you very much!! This is really the missing piece for a huge chunk of potential automation.
Thu Sep 29, 2016 4:16 pm
durosity offline
Feature Request (Well assuming it's not already possible and i've just missed it)
I'd love the ability to have a single action (for use on control pages) that'd map to the current activity automatically. EG if i press a pause on a control page it'd invoke the pause function on the activity currently active. This can be done already by way of having an action group for all the different functions and then have a script for each one that pulls that action group of the button is pressed for the relevent activity running at that time. It'd just be much easier to have it all in the plugin than having about 200-300 different action groups and scripts setup :)
Thu Sep 29, 2016 5:20 pm
I'll see how hard that would be to do.
Thu Sep 29, 2016 5:37 pm
durosity offline
Cool. It would make life so much easier. I'm currently transitioning away from using the GC100/iTach combo I've been using the last few years to using two hubs and everything has went exceptionally smoothly except this part. I already have lots of action groups for this stuff so I COULD go through and modify them accordingly, BUT it'd be so much easier to ditch all the action groups and just have it all go through the plugin. It's kinda the last puzzle in simplifying my indigo system.. (at least until I7 comes along and I have to start work alllll over again)
Sun Oct 09, 2016 10:26 am
nev offline
How could I script a reload of this plugin?
Sun Oct 09, 2016 10:30 am
plugin = indigo.server.getPlugin("com.flyingdiver.indigoplugin.harmonyhub")
if plugin.isEnabled():
   plugin.restart()
