Is there such a thing as a raw command, python script or possibly a parameter setting that would allow 'live' dimming of this controller?
Trying to stay within my Insteon/Z-wave device pool and so far have a KPL set up to:
- send the On/Off command - just turning the LED strips on to white (or last color remembered) at a set % using Indigo Insteon On/Off command.
- DIM/Brightens by a % commands on 2 more buttons set to non-toggle mode
- some other buttons triggering the 5 very cool scenes available in Parameter 72. ( will eventually incorporate these into a single button somehow lol.)
- I have a freeze button that stops a scene (parm 72 program) when the program lands on a color that is desirable to keep. e.g - the Rainbow program has some deep colors that are really cool so the user can freeze that color and keep ite for as long as they want, just a geeky feature by setting parm 72 to 1 but really works well.
Not perfect yet but getting there. Surprisingly the KPL with this setup is looking like a great candidate as a physical switch for the LED lights using this controller. If dimming worked better the above basic setup would give the user a full palette of collor and patterns to choose from without burning up too much gray matter lol.
In order to make dimming workable the trigger Dims/Brightens in steps of 20% to minimize the number of touches to the KPL button so it doesn't work as expected of a true dimmer. I'm just using a trigger linked to the button and dimming/Brightening the composite . What would be great is having the controller dim/Bright as the On/Off button is pressed like any other Insteon switch. At first I didn't think this possible (hence the present setup) knowing that the Insteon linking system directly controls dimming functions to Insteon devices on button hold so using Indigo Triggers to dim to a set % was the only option... until I looked into the Dimmer Extender plugin's functionality. This plugin one can trigger on the 'start/stop dimming/brighten status of a toggle button and it got me thinking about sending a dim start and dim stop command to the controller if that was possible. I tried to use the plugin directly but it doesn't recognize the controller.
If there is either a DIM/BRIGHTEN raw command, python script, or a parameter that can control the dim/brighten function, it would be very helpful in providing control on a KPL right there on the counter as a manual switch, as there is little waf interest in changing to another switch in the new kitchen if I can avoid it.
Thanks for reading. Any ideas greatly appreciated. I'm stuck but think/hope I'm on to something here
Jim
