Not finding the smartphones
Thu Sep 01, 2016 9:32 am
captcurrent offline
I have assigned static IPs to my smartphones and Have tried using both the IP and the MAC address to try to "find" the phones.. No joy
The phones are show as attached to the routers network map
But still show as away
I am seeing this meesage
2016-09-01 10:31:03.745 Smartphone Radar Router Log: <3>Sep 1 10:31:03 drumfish afctl[20156]: *** Terminating app due to uncaught exception 'NSRangeException', reason: '*** -[NSCFArray objectAtIndex:]: index (1) beyond bounds (1)'\n*** Call stack at first throw:\n(\n 0 CoreFoundation 0x00007fff87c11784 __exceptionPreprocess + 180\n 1 libobjc.A.dylib 0x00007fff8003cf03 objc_exception_throw + 45\n 2 CoreFoundation 0x00007fff87c115a7 +[NSException raise:format:arguments:] + 103\n 3 CoreFoundation 0x00007fff87c11534 +[NSException raise:format:] + 148\n 4 Foundation 0x00007fff88bbfca4 _NSArrayRaiseBoundException + 122\n 5 Foundation 0x00007fff88b22dad -[NSCFArray objectAtIndex:] + 75\n 6 afctl 0x0000000100003028 0x0 + 4294979624\n 7 afctl 0x00000001000026e6 0x0 + 4294977254\n 8 afctl 0x0000000100002f6b 0x0 + 4294979435\n 9 afc
2016-09-01 10:31:04.244 Smartphone Radar Router Log: <5>Sep 1 10:31:03 drumfish com.apple.afctl[20156]: terminate called after throwing an instance of 'NSException'
I dont even have a clue to start to decypher Any help would be appreciated
Thu Sep 01, 2016 9:41 am
durosity offline
Re: Not finding the smartphones
What kind of wifi base station do you have?
Thu Sep 01, 2016 10:25 am
captcurrent offline
ASUS RT_AC66U
Sat Sep 03, 2016 8:08 am
captcurrent offline
Bump or does this only work with apple airports
Sat Sep 03, 2016 8:18 am
durosity offline
I might suggest you look at the FINGSCAN plugin, from memory it excels with asus routers and is more reliable than other ones that use smnp traffic monitoring.
Sat Sep 03, 2016 11:38 am
captcurrent offline
regterably there is no longer any documentation for that plugin
thanks for the suggestion
worked around by using an applescript not elegant but it works
