SecuritySpy to iMessage Trigger
Tue Aug 23, 2016 4:10 pm
petematheson offline
Hi There,
I'm new to security spy, and have installed my first camera (a Hikvision).
I have the latest version of Security Spy installed on my Mac (same one running indigo) and I have configured it to record on motion.
What I can't figure out is how to create a trigger in Indigo to send me an iMessage with a photo or video of the camera.
Something like, if house is empty and doorbell is pushed - send iMessage with CCTV snapshot attached.
Tue Aug 23, 2016 4:18 pm
Re: SecuritySpy to iMessage Trigger
After a bit more searching I can see that I can pull the image via the url for a control page:
http://xxx.xxx.xxx.xxx/Streaming/channels/1/picture
Just wondering if this feature was built into this plugin at all before I look down the route of how I download this image and then attach it to an iMessage somehow?
Tue Aug 23, 2016 4:30 pm
ELWOOD offline
Look at the preference settings in the security spy you can setup an email account and than security spy will send
4 pics of the video feed with motion or by an action in indigo. Using the motion does tend to send a lot of false trigers
due to changes in lighting with outside cameras.
Elwood
Tue Aug 23, 2016 4:34 pm
Yeah - but that's why I wanted to use Indigo to do the messaging side of things - because then I can specify only to send me a picture when the doorbell is pushed / house is empty :)
Tue Aug 23, 2016 4:52 pm
ELWOOD offline
I have a trigger in indigo that fires when my delivery door is opened.
with an action of Trigger Recording of device "front door camera"
Here is todays delivery
Elwood
Front door 08-23-2016 14-12-01 1.jpg (156.72 KiB) Viewed 2929 times
Tue Aug 23, 2016 6:38 pm
Sending an email or a text is fairly easy. But I don't know of any way to send an iMessage from Indigo.
Break it down into two parts - first get the trigger working the way you want, even if it doesn't actually do anything. Then work on getting the notification you want.
Tue Aug 23, 2016 7:57 pm
I haven't done a ton with Applescript, but I had this code snippet in my archive:
tell application "Messages"
   send "This is an SMS" to buddy "+1234567890" of service "SMS"
end tell
If I recall, you can't iMessage yourself at an email alias, but you can iMessage yourself to a phone number alias (I just tested it.) I also believe that (to work as written) iMessage needs to be running--but I'm not positive of that last bit.
Dave
Tue Aug 23, 2016 8:06 pm
peteinau offline
Hey,
I use the following AppleScript code to take a picture from the camera and then send it via iMessage if it helps you
set garage_pic to "/Users/admin/Downloads/garage.jpg"
tell application "SecuritySpy"
capture image camera name "Garage" as garage_pic with overwrite
end tell
set DestFile to POSIX file "/Users/admin/Downloads/garage.jpg"
send file DestFile to buddy "User"
end tell
Wed Aug 24, 2016 4:49 pm
Perfect, thanks @peteinau
For the others on here, yep you can iMessage yourself. I have my Mac Mini running with a separate iCloud account.
