Device recording
Fri Aug 05, 2016 5:02 pm
Asconasny offline
Device recording
Hi
I have an arduino with a couple of dht22 sensors and I'm trying to plot the output..
looks like the temp is resetting and start over at 00:00 but humidity shows correct
I can't figure out what i have done wrong in this graf
Anyone have had the same issue, and maybe have the answer how to fix it?
Regards
Asconasny
Sat Aug 06, 2016 12:28 am
Re: Device recording
Use utilities and print the real data. Is it data from arduino or a plot issue.
it looks as if the data is simply =0 before midnight, not just a "reset"
Sat Aug 06, 2016 7:23 am
Asconasny offline
Hi
Thanks for the reply.
I had a look in the database with sqlitebrowser, and the data is there.
Arduino is reporting and temp is being saved in the database.
So i would assume there is something else going on.
regards
Asconasny
Sat Aug 06, 2016 9:09 am
Device recording
Could you look at the file ~/documents/indigoplotd/sql/
Then the devicenumber.state_s0. Or what ever the state u use
Sat Aug 06, 2016 12:46 pm
Asconasny offline
its logging.
There is input in the file... same as the database.
Screenshot is from a hour before it "reset"
strange..
Screen Shot 2016-08-06 at 20.33.15.png (141.04 KiB) Viewed 2857 times
Sat Aug 06, 2016 1:20 pm
you could try:menu/"reload single device/state from sql". that should reload all data through the whole chain.
Sun Aug 07, 2016 7:49 am
Asconasny offline
Jupp,, that seems to work. :)
I have been thinking for a while, i want to use postgresSQL. since as i understand it, is supposed to be better on big databases.
So i might as well start fresh.
Fresh database and fresh IndigoplotD.
I have installed postgres, (Used http://postgresapp.com) and removed Indigoplot completely, (disable plugin, and deleted in Disable plugin folder. Also deleted plugin preference) Deleted all plot devices.
Long time ago i created some simple plots. via the simple plot menu. , and IndigoplotD seems to still think they are there.
INDIGOplotD /Users/indigo/Documents/INDIGOplotD/gnu/Energi-minute-S1.gnu has no lines defined -- dont forget to click CONFIRM before you save the lines and plots, ignore this warning if just created
INDIGOplotD /Users/indigo/Documents/INDIGOplotD/gnu/ToerkeSkap-minute-S1.gnu has no lines defined -- dont forget to click CONFIRM before you save the lines and plots.
My question is: How do i delete simple plots/configuration?
regards
Asconasny
Sun Aug 07, 2016 9:18 am
Are there any plot device still present? Do a sort of devices with column model/ type there should be some devices left.
Sun Aug 07, 2016 11:53 am
Asconasny offline
Kinda embarrassing..
Your correct.
Found them :)
