Onkyo Network Remote Feedback and Discussion
Tue May 10, 2016 6:34 am
Busta999 offline
Onkyo Network Remote Working Great
Just wanted to say a big thank you.
Using all the time.
Much appreciated :-)
Mike
Tue May 10, 2016 7:44 pm
RogueProeliator offline
Re: Onkyo Network Remote Feedback and Discussion
No problem at all - thanks for posting... glad to hear there are some happy users out there!
Wed May 25, 2016 6:55 am
Can anyone confirm either way if the TX-SR607 is compatible with this plugin? Just ran across one for sale here on CL.
My intuition says "no'' since I'm betting the N in the model numbers of all the listed compatible ones stands for "network."
Wed May 25, 2016 8:03 am
I think I've answered my own question by looking at the back panels of N series receivers vs the SR series. N series have an ethernet port and the SR doesn't.
Wed Jun 29, 2016 7:14 am
bobbyc176 offline
Thanks for a great plug in! It's working well so far with my TX-RZ800.
One question though. It's not clear to me how I can pull back the following variables so that I can keep my control pages updated:
Current Input (Main)
Current Input (Zone 2)
Mute Status (Main)
Mute Status (Zone 2)
Listening Mode
NetworkPlay Album
NetworkPlay Artist
NetworkPlay Title
Tuner Frequency
Rob
Wed Jun 29, 2016 10:40 am
Mute Status (Main)
Listening Mode
NetworkPlay Album
NetworkPlay Artist
NetworkPlay Title
Tuner Frequency
Hey Rob... Those are all exposed as Device States - so you need only set the control page element as:
"Device State" > For [select your receiver] -> State
You don't want to select any virtual volume controllers setup, but rather the Receiver Indigo Device. The labels should be obvious - Current Input, Is Muted, Streaming Title, etc. Note that the album/artist/title is only shown for certain inputs and not all receiver models support it. I want to say we have a user using it for Pandora successfully.
Thu Jun 30, 2016 6:12 pm
bobbyc176 offline
Well lookey-there! Right under my nose.
I made it more complicated than it needed to be (I have a gift for that!)
Thank you!
Rob
Mon Aug 01, 2016 7:26 am
hamw offline
I'm starting to get an error on my plugin "Connection failed for device XXXXXXX: [Errno60] Operation timed out"
I can access the receiver via Safari at its static IP and modify/save without difficulty. While the plugin seems to engage for a few minutes with the status indicators green, in looking at the log at medium debugging it states it acquires status but is able to change the station or receive updates. Following the failed status request the indicators turn red and throw the error while I am watching it. No other odd behavior from the system or network. Anything I should check? Powercycle the unit?
thanks!
Enabling plugin "Onkyo Network Remote Plugin 2.0.0"
Starting plugin "Onkyo Network Remote Plugin 2.0.0" (pid 34157)
Started plugin "Onkyo Network Remote Plugin 2.0.0"
Aug 1, 2016 9:15:55 AM
Onkyo Network Remote Plugin Error Connection failed for device 300788196: [Errno 60] Operation timed out
Onkyo Network Remote Plugin Error Connection failed for device 367370760: [Errno 60] Operation timed out
Onkyo Network Remote Plugin Debug Plugin preferences updated
Onkyo Network Remote Plugin Debug Establishing connection to XXX.XX.XX.XX
Onkyo Network Remote Plugin Debug Connection established
Onkyo Network Remote Plugin Debug Received direct tune action to 092.30
Onkyo Network Remote Plugin Debug Sending tune command for 09230
Aug 1, 2016 9:16:27 AM
Onkyo Network Remote Plugin Debug Received direct tune action to 094.90
Onkyo Network Remote Plugin Debug Sending tune command for 09490
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZ2B
Onkyo Network Remote Plugin Debug Attempting reconnection to device 300788196
Onkyo Network Remote Plugin Debug Establishing connection to 10.0.1.63
Onkyo Network Remote Plugin Debug Attempting reconnection to device 367370760
Onkyo Network Remote Plugin Debug Create connection command de-queued
Onkyo Network Remote Plugin Debug Executing full status update request...
Onkyo Network Remote Plugin Debug Sending eISCP Command: PWRQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: MVLQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: AMTQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: HAOQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLIQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SPAQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SPBQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLPQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: HDOQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: RESQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: VWMQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: VPMQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: LMDQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLAQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: TUNQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NATQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NALQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NTIQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: NSTQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: ZPWQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZQSTN
Onkyo Network Remote Plugin Debug Sending eISCP Command: ZVLQSTN
Aug 1, 2016 9:17:08 AM
Onkyo Network Remote Plugin Debug Scheduling reconnection attempt...
Onkyo Network Remote Plugin Debug Reconnection attempt scheduled for 30 seconds
Onkyo Network Remote Plugin Debug Closing connection to device
Aug 1, 2016 9:17:36 AM
Mon Aug 01, 2016 8:15 pm
It looks like you may have two Indigo devices attempting to connect? Are they both going to the same receiver? I ask because that could cause some issues there (potentially)... otherwise, turn the debug up to high, disable the plugin, reboot the receiver, then start the plugin back up again. That should give a ton of log file information...
Adam
Thu Aug 04, 2016 8:32 pm
hamw offline
I was away for the weekend and unable to access the Onkyo. For some reason it seems is got into a funk and had to be unplugged. I have since plugged it into my Digital Loggers ethernet power switch so that I can control and reset it remotely.
In any case the plugin seems to be working fine now. I set it up with two devices, one for Main and the other for Zone 2. Maybe I didn't dig hard enough, but it seemed like the functionality was better with two devices. So far, with the exception of this one hiccough, it has worked well. Will report back as needed.
Thanks again for a GREAT plugin!
Thu Aug 04, 2016 9:36 pm
You have one setup as a Receiver device and one as a Virtual Volume Controller or both setup as full Receiver devices? I have mine setup as a virtual volume device and as far as I can tell works just fine... not sure that two simultaneous connections are supported if you have two full receiver devices. But I guess if it has been working, so be it!
No problem at all... let me know if your issues return and we need to look into it further!
Adam
Fri Aug 05, 2016 5:04 am
hamw offline
I am using it as two separate receiver devices and it works fine. As I need a preamp hotly I use the zone 2 for my WHA source.
One thing I can't figure out is how to set up and select a pandora station via the plugin. Is that possible? Does it use the web interface list? If not, is it possible to set up the actual Onkyo app so that it can open from a URL call in Indigo, like the apple remote app can?
Fri Aug 05, 2016 8:43 am
Honestly, I have no idea whatsoever... however, I just looked at the command dump and there is an "Internet Radio Preset Command" that accepts a number which is presumably the preset. If you have a preset defined, try entering these into the "Send Arbitrary Command" option (from the Plugins menu) and see if it changes to the preset (not 100% sure the format, if one works, no need to send another):
NPR1
NPR01
Note that the number may bein hexadecimal format, so try with a preset in the 1-9 range first. If that works, we can add it to the plugin as an action pretty darn easily.
Adam
Sun Aug 07, 2016 12:21 pm
hamw offline
Here is the URL for accessing the Onkyo Remote app: onkyo-remote3://
Put the URL on a control page and it will switch to the Remote app to let one directly select stations. Then one can switch back to Indigo Touch.
Probably a lot easier to use this than figuring out all this stuff below.... :D
Turned on debugging and ran NPR1; no result. However, NPR01 gave this feedback. This is the HD audio stream from my local NPR station, WABE. I set it up in "TuneIn" as I believe is supposed to be done. tunein.com/radio/WABE-News-901-s67046/
Onkyo Network Remote Plugin Debug Command queue has 1 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: NPR01
Onkyo Network Remote Plugin Debug Send command completed.
Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NLT0122000000000001000100
Onkyo Network Remote Plugin Debug Received w/o Command: !1NLT0122000000000001000100
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-list-info', 'C-P')
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-jacket-art', 'n-')
Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NLTF33200000001000000FF00Playback error
Onkyo Network Remote Plugin Debug Received w/o Command: !1NLTF33200000001000000FF00Playback error
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-list-info', 'C0P')
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-list-info', 'U0-Popup cannot be supported')
Onkyo Network Remote Plugin Debug Failed to parse eISCP message, message ignored: !1NCPX<?xml version="1.0" encoding="utf-8"?><popup title="Playback error" align="center" type="custom" time="0" uri="resource:///popup" ><label title="" align="center" total="1" uri="resource:///popup/label:0" ><line text="Connection Error. · The server connection could not be established or was terminated early. Please try again later." align="left" uri="resource:///popup/label:0/line:0" order="0" /></label><buttongroup title="" align="center" total="1" uri="resource:///popup/buttongroup:0" ><button text="Back" align="center" uri="resource:///popup/buttongroup:0/button:0" selected="false" index="0" order="1" /></buttongroup></popup>
Onkyo Network Remote Plugin Debug Received w/o Command: !1NCPX<?xml version="1.0" encoding="utf-8"?><popup title="Playback error" align="center" type="custom" time="0" uri="resource:///popup" ><label title="" align="center" total="1" uri="resource:///popup/label:0" ><line text="Connection Error. · The server connection could not be established or was terminated early. Please try again later." align="left" uri="resource:///popup/label:0/line:0" order="0" /></label><buttongroup title="" align="center" total="1" uri="resource:///popup/buttongroup:0" ><button text="Back" align="center" uri="resource:///popup/buttongroup:0/button:0" selected="false" index="0" order="1" /></buttongroup></popup>
this is a pandora station set up as NPR02. http://www.pandora.com/station/play/1898301078810978435
Onkyo Network Remote Plugin Debug Sending eISCP Command: NPR02
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-artist-name-info', '---')
Onkyo Network Remote Plugin Debug Found response match: streamingArtistQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayArtist" to "---"
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-album-name-info', '---')
Onkyo Network Remote Plugin Debug Found response match: streamingAlbumQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayAlbum" to "---"
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-title-name', '1898301078810978435')
Onkyo Network Remote Plugin Debug Found response match: streamingTitleQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayTitle" to "1898301078810978435"
Onkyo Network Remote Plugin Debug Received w/o Command: ('net-usb-track-info', '----/----')
Sun Nov 20, 2016 11:47 am
gskarp offline
I love this plugin. However it seems broken under Indigo 7. Has anyone else encountered problems with it? Seems to still work fine with Indigo 6.
Page 8 of 11 1 ... 5, 6, 7, 8, 9, 10, 11
