Precision of values
Sat Jun 11, 2016 12:01 pm
Nine offline
Precision of values
If I set the precision of some values in the config to 0:
Bildschirmfoto 2016-06-11 um 19.54.09.png (97.26 KiB) Viewed 1690 times
the WUnderground-Device shows everything correctly:
Bildschirmfoto 2016-06-11 um 19.54.22.png (25.01 KiB) Viewed 1690 times
But if I then write out the value of eg the max temp to a variable, there is a decimal place:
Bildschirmfoto 2016-06-11 um 19.54.31.png (8.38 KiB) Viewed 1690 times
Is that a bug or make I a mistake?
Nine
Sat Jun 11, 2016 12:54 pm
Re: Precision of values
Neither. Indigo has the capacity to maintain two values for each device state--(1) the actual state value, and (2) one to display in Indigo's UI. When you change the decimal precision value in the plugin, you're affecting only the UI value (the actual value remains unchanged.) This is purposeful behavior.
How are you writing out the value to the variable? If you're using Python, it's an easy fix.
x = indigo.devices[1258163860].states["foreHigh1"]
y = indigo.devices[1258163860].states["foreHigh1.ui"]
indigo.server.log(unicode(x))
indigo.server.log(unicode(y))
Which yields this:
Jun 11, 2016, 1:53:22 PM
  Script                          93.0
  Script                          93°
Sun Jun 12, 2016 3:28 am
Nine offline
Thx for your explanations Dave. I can not use "foreHigh1.ui" because the TTS for german does not speak the degree-sign correctly (it says "degree-sign" instead of "degree")... so I will have to convert the "foreHigh1" to a number without decimal place...
Nine
Sun Jun 12, 2016 5:17 am
That sounds like the best approach to me, too. Good luck!
