I recommend saving the image to the Indigo static images folder. It's probably not necessary to run the script regularly (assuming that the network doesn't change that frequently) and it's probably most useful to run the script right before examining the output. When a device is included or excluded, the chart will adjust accordingly (the next time the script is run.) Color is meaningful and I've added a "color blind" feature in case the color differences are too subtle for some (see below.) Note that the script can take a fair bit of time to complete--especially on slower servers and/or larger networks. The script will write a message to the log when it's done. I will continue to try to add lightness where I can. Each node on the X axis displays its corresponding neighbors vertically. The resulting figure can be used to answer questions such as:
- which devices are not associated with node 1?
- which devices show neighbors that are no longer in the network?
EDIT 1: corrects mixture of tabs and spaces.
EDIT 2: Adds features to plot battery devices in a different color (white dot, red border in example), highlight devices not associated with node 1 (red dot in example) and own node (gray dot in example.) These new features are optional.
EDIT 3: Adds feature to hide unused node numbers, moves indication of devices not associated with node 1 to the x-axis label to avoid obscuring other indicators (colored text on X axis), adds indication of neighbors with unused nodes (colored text on Y axis), adds optional legend.
EDIT 4: Adds optional color blind feature to make certain indications more prominent.
- Code: Select all
#! /usr/bin/env python2.6
# -*- coding: utf-8 -*-
import sys
import matplotlib.pyplot as plt
import numpy as np
except ImportError, e:
sys.exit(u"The matplotlib and numpy modules are required to use this script.")
# =================== User Settings ===================
output_file = '/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/controls/static/neighbors.png'
title_font_size = 9
chart_title = 'node matrix'
x_axis_title = 'node'
y_axis_title = 'neighbor'
background_color = '#000000'
font_color = '#888888'
font_name = 'Lato Light'
tick_font_size = 6
foreground_color = '#888888'
node_border = '#66FF00'
node_color = '#FFFFFF'
node_marker = '.'
# If True, each node that is battery powered will be highlighted.
plot_battery = True
node_border_battery = '#FF0000'
# If True, devices with node 1 missing will be highlighted.
plot_no_node_1 = True
node_1_missing = '#FF0000'
# If True, neighbors without a corresponding node will be highlighted.
plot_no_node = True
node_missing = '#000099'
# If True, each node will be plotted as its own neighbor.
plot_self = True
plot_self_color = '#333333'
# If True, unused node addresses will be plotted.
plot_unused_nodes = False
# If True, display a chart legend.
show_legend = True
# If True, additional annotations will be used beyond color.
color_blind = False
color_blind_marker = 'x'
# =================== kwarg Settings ===================
# To minimize the blank space surrounding the chart, add bbox_inches='tight' to kwarg_savefig. This causes the chart's dimensions to be dynamic.
kwarg_savefig = {'bbox_extra_artists': None,
'dpi': 100,
'edgecolor': background_color,
'facecolor': background_color,
'format': None,
'frameon': None,
'orientation': None,
'pad_inches': 0.1,
'papertype': None,
'transparent': True}
kwarg_title = {'color': font_color,
'fontname': font_name,
'fontsize': title_font_size}
# Matplotlib will decide the optimal figure size on its own. If you want to give the chart constrained dimensions, uncomment the next line.
# Figsize values are in inches. The saved image will be inches x DPI. In other words, a chart that is 7" x 7" will yield a chart 700 x 700 at
# 100 DPI (set above in the kwarg_savefig parameters.).
# plt.figure(figsize=(7, 7))
# CODE BELOW THIS LINE SHOULD GENERALLY NOT NEED TO BE CHANGED.
# Build the master dictionary of the Z-Wave Mesh Network.
address_list = []
final_devices = []
no_node_1 = []
max_addr = 0
# Iterate through all the Z-Wave devices and build a dictionary.
for dev in indigo.devices.itervalues('indigo.zwave'):
neighbor_list = list(dev.globalProps['com.perceptiveautomation.indigoplugin.zwave']['zwNodeNeighbors'])
supports_battery = dev.globalProps['com.perceptiveautomation.indigoplugin.zwave']['SupportsBatteryLevel']
address_list.append(int(dev.address))
final_devices.append([int(dev.address), dev.name, neighbor_list, supports_battery])
if max_addr < int(dev.address):
max_addr = int(dev.address)
except Exception, e:
pass
# Take the master list, sort it, and add a counter element for later charting.
counter = 1
for item in sorted(final_devices):
item.append(counter)
counter += 1
# Assign consecutive keys to neighbor nodes for plotting when unused nodes are not plotted.
neighbor_list = []
for device in sorted(final_devices):
for neighbor in device[2]:
if neighbor not in neighbor_list:
neighbor_list.append(neighbor)
if device[0] not in neighbor_list:
neighbor_list.append(device[0])
counter = 1
dummy_y = {}
for neighbor in sorted(neighbor_list):
if neighbor not in dummy_y.keys():
dummy_y[neighbor] = counter
counter += 1
# ================== Lay Out The Plots ==================
# This plot will show all Z-Wave neighbors on the plot.
if plot_unused_nodes:
plt.plot(device[0], neighbor, color=node_border, marker=node_marker, markerfacecolor=node_color, zorder=10)
plt.plot(device[4], dummy_y[neighbor], color=node_border, marker=node_marker, markerfacecolor=node_color, zorder=10)
# This plot provides an overlay for battery devices.
if device[3] and plot_battery and plot_unused_nodes:
if color_blind:
plt.plot(device[0], neighbor, color=node_border_battery, marker=color_blind_marker, markerfacecolor=node_color, zorder=10)
plt.plot(device[0], neighbor, color=node_border_battery, marker=node_marker, markerfacecolor=node_color, zorder=10)
elif device[3] and plot_battery:
if color_blind:
plt.plot(device[4], dummy_y[neighbor], color=node_border_battery, marker=color_blind_marker, markerfacecolor=node_color, zorder=10)
plt.plot(device[4], dummy_y[neighbor], color=node_border_battery, marker=node_marker, markerfacecolor=node_color, zorder=10)
# This plot provides an additional overlay over devices that don't report node 1 as a neighbor.
if plot_no_node_1 and not device[2]:
indigo.server.log(' Device %s is valid, but has no neighbors. Skipping.' % device[0])
elif plot_no_node_1 and device[2][0] != 1 and plot_unused_nodes:
no_node_1.append(int(device[4]) - 1)
elif plot_no_node_1 and device[2][0] != 1 and not plot_unused_nodes:
# This plot will assign a point to a node for its own address (plot itself.)
if plot_self and plot_unused_nodes:
for me in np.arange(2, max_addr, 1):
plt.plot(me, me, color=plot_self_color, marker=node_marker, markerfacecolor=plot_self_color, zorder=10)
elif plot_self:
plt.plot(device[4], dummy_y[device[0]], color=plot_self_color, marker=node_marker, markerfacecolor=plot_self_color, zorder=10)
except IndexError, e:
indigo.server.log("%s - %s" % (device[0], e), isError=True)
except KeyError, e:
indigo.server.log("%s - %s. Skipping." % (device[0], e), isError=True)
pass
indigo.server.log("%s - Problem building node matrix: %s" % (device[0], e), isError=True)
pass
# =================== Chart Settings ===================
plt.title(chart_title, **kwarg_title)
for spine in ['top', 'bottom', 'left', 'right']:
plt.gca().spines[spine].set_color(foreground_color)
plt.tick_params(axis='both', which='both', labelsize=tick_font_size, color=foreground_color)
# =================== X Axis Settings ===================
plt.xlabel(x_axis_title, fontsize=title_font_size, color=foreground_color)
plt.tick_params(axis='x', bottom=True, top=False)
plt.xticks(np.arange(1, max_addr + 1, 1), fontsize=tick_font_size, color=foreground_color)
plt.xlim(1, max_addr + 1)
plt.xticks(np.arange(1, len(final_devices) + 1, 1), sorted(address_list), fontsize=tick_font_size, color=foreground_color)
plt.xlim(0, len(final_devices) + 1)
# =================== Y Axis Settings ===================
plt.ylabel(y_axis_title, fontsize=title_font_size, color=foreground_color)
plt.tick_params(axis='y', left=True, right=False)
plt.yticks(np.arange(1, max_addr + 1, 1), fontsize=tick_font_size, color=foreground_color)
plt.ylim(0, max_addr + 1)
plt.yticks(np.arange(1, max_addr, 1), sorted(dummy_y.keys()), fontsize=tick_font_size, color=foreground_color)
plt.ylim(0, len(dummy_y) + 1)
# =================== Legend Settings ===================
if show_legend:
foo1, = plt.plot([], color=node_border, linestyle='', marker=node_marker, markerfacecolor=node_color)
if color_blind:
foo2, = plt.plot([], color=node_border_battery, linestyle='', marker=color_blind_marker, markerfacecolor=node_color)
foo2, = plt.plot([], color=node_border_battery, linestyle='', marker=node_marker, markerfacecolor=node_color)
foo3, = plt.plot([], color=plot_self_color, linestyle='', marker=node_marker, markerfacecolor=plot_self_color)
foo4, = plt.plot([], color='blue', linestyle='', marker=node_marker, markerfacecolor='blue')
foo5, = plt.plot([], color=node_1_missing, linestyle='', marker=node_marker, markerfacecolor=node_1_missing)
legend = plt.legend([foo1, foo2, foo3, foo4, foo5], ['neighbor', 'battery', 'self', 'no node', 'no node 1'], bbox_to_anchor=(1, 0.5), fancybox=True, loc='best', ncol=1, numpoints=1, prop={'size': 6.5})
legend.get_frame().set_alpha(0)
for text in legend.get_texts():
text.set_color(font_color)
# ======== Color labels for nodes with no node 1 ========
if plot_no_node_1 and no_node_1:
foo_x = [i for i in plt.gca().get_xticklabels()]
if not plot_unused_nodes:
for node in no_node_1:
foo_x[node].set_color(node_1_missing)
if color_blind:
foo_x[node].set_weight('bold')
foo_x[node].set_backgroundcolor('white')
foo = sorted(final_devices)
a = foo[node][0]
foo_x[a-1].set_color(node_1_missing)
if color_blind:
# ========= Color labels for neighbors with no node ========
if plot_no_node:
foo_y = [i for i in plt.gca().get_yticklabels()]
for a in dummy_y.keys():
if a not in address_list:
if a != 1:
a = dummy_y[a] - 1
foo_y[a].set_color(node_missing)
if color_blind:
foo_y[a].set_weight('bold')
foo_y[a].set_backgroundcolor('white')
a -= 1
if color_blind:
# ========= Output the Z-Wave Node Matrix Image =========
plt.savefig(output_file, **kwarg_savefig)
indigo.server.log("Chart output error: %s:" % e)
# Wind things up.
plt.close()
indigo.server.log("Z-Wave Node Matrix generated.")
