Honeywell Errors in 0.4.4
Sat May 07, 2016 3:40 pm
petematheson offline
Hey,
Getting this error repeatedly - think it was the same one I used to get pre-release?
File "plugin.py", line 53, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.IndigoPlugin/Contents/Server Plugin/Honeywell.py", line 160, in runConcurrentThread
<type 'exceptions.UnboundLocalError'>: local variable 'evohome_timer_refresh' referenced before assignment
Honeywell Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Sat May 21, 2016 5:04 am
neilk offline
Re: Honeywell Errors in 0.4.4
Pete,
I am also periodically getting the same error, restarting the plugin clears it and I see no pattern to the cause.
Neil
Sat May 21, 2016 6:31 am
Yep, same here - restart gets it working again until the next time.
Sat May 21, 2016 6:52 am
nlagaros offline
Hoping to have a release very soon... 1/2 way through cleaning up the code.
Thu Jun 23, 2016 7:41 am
jalves offline
I'm getting this error as well. Here's what it looks like in my log:
Honeywell Error Error in plugin execution runConcurrentThread:
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.IndigoPlugin/Contents/Server Plugin/Honeywell.py", line 125, in runConcurrentThread
UnboundLocalError: local variable 'timer_refresh' referenced before assignment
As with the others, restarting it clears the error. I've not been able to discern any connection between activities and the occurrence of the error. Once it starts, it repeats almost continuously.
Jeff
Thu Jun 23, 2016 11:07 am
exos offline
I am having same issue. Will not go away after restart. Here's what I show.
Disabling plugin "Honeywell 0.4.4"
Stopping plugin "Honeywell 0.4.4" (pid 7284)
Stopped plugin "Honeywell 0.4.4"
Enabling plugin "Honeywell 0.4.4"
Starting plugin "Honeywell 0.4.4" (pid 7296)
Started plugin "Honeywell 0.4.4"
Honeywell Your plugin version, v0.4.4, is current.
Honeywell Saved Plugin Configuration
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.IndigoPlugin/Contents/Server Plugin/Honeywell.py", line 94, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.IndigoPlugin/Contents/Server Plugin/Honeywell.py", line 187, in initDevice
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.IndigoPlugin/Contents/Server Plugin/Honeywell.py", line 1349, in updateStateOnServer
KeyError: key humidityInput1 not found in dict
However, after a few cycles my only error is:
Thu Jun 23, 2016 11:11 am
I'm not sure if Nick is around at the moment - not seen any update on this plugin for about a month.
Thu Jun 23, 2016 4:34 pm
nlagaros offline
Sorry folks.. I've been doing a lot of travelling and have really been out of the mix. I'm back next week and will try to catch up on the backlog.
Thu Jun 23, 2016 4:45 pm
No worries Nick.
At least it's not Ill health.
