Indigo / Applescript Tutorial?
Sun Aug 17, 2008 9:29 pm
jaedendak offline
Is there a tutorial anywhere that can help me get started with apple script and indigo? I'm looking for something specific to indigo. I've already found some tutorials for apple script in general, but I'm really only interested in use with indigo for now.
Sun Aug 17, 2008 9:58 pm
Re: Indigo / Applescript Tutorial?
There isn't a specific tutorial I know of, but the sample scripts are a good place to start:
/Library/Application Support/Perceptive Automation/Indigo 2/Scripts/
Additionally, our User Contribution Library has some great scripts. If there is anywhere in particular you get stuck, then let us know and I'm sure someone can help you out.
Regards,
Matt
Sat Oct 10, 2015 7:56 pm
philipbasile offline
Matt,
This applescript used to work fine I don't know whats changed but for some reason it displays the system message fine, so I know its running but then never logs to indigo. Do you see anything I'm doing wrong ?
on GoGoGeohop(email, subject)
tell application "System Events" to display dialog "Loc Event - " & subject & " " & time string of (current date)
end tell
end GoGoGeohop
Sun Oct 11, 2015 4:58 pm
I'm not sure, but if you move the dialog showing to after the tell IndigoServer block (after the end tell) does it still show up? And does it log to Indigo in that case?
Sun Oct 11, 2015 7:27 pm
matt,
after further forum reading, am I running into the known applescript not talking to indigo bug ?
Philip
Sat Apr 30, 2016 11:20 am
Maybe I'm missing the resource I need, but looking through the recommended sources above, I still don't find what I need.
The AS dictionary doesn't give me examples. (Ok, I can get, and there is device, but can I get the status of a device?
The included scripts are too high level and abstracted for what I need. They typically are iterating through self-generating lists of devices, not addressing a device.
I need an example that does something like this, which I'm sure is full of mistakes, but this would be my first guess on how to write the script:
set output to status of device "Current Conditions:Forecast day 2"
end tell
I can't find the proper way to address "Forecast Day 2" when it's a subset of a device, and I can't figure out how to ask Indigo for the status once I know what thing to ask.
Sat Apr 30, 2016 12:04 pm
Custom plugin device information and states aren't available via AppleScript. We encourage using python scripting model going forward whenever possible.
Sat Apr 30, 2016 12:21 pm
RogueProeliator offline
I believe others put a trigger on the change of the state and push that status to a variable, which is then exposed to the outside APIs. It is an extra step, but not terrible if you only need a few exposed like that.
Adam
Sat Apr 30, 2016 1:01 pm
Sat Apr 30, 2016 2:33 pm
Here's another puzzler.
   set value of variable CamMotion to "true"
end tell
results in: error "The variable CamMotion is not defined." number -2753 from "CamMotion"
Except there the variable is in my Variable List. I tried referencing it by ID and that didn't work either.
Sat Apr 30, 2016 2:35 pm
Add quotes around CamMotion.
Sat Apr 30, 2016 2:57 pm
Gah!
Thank you!
Sat Apr 30, 2016 5:28 pm
I just want to reiterate here - Python is the future of scripting in Indigo. Unless you're specifically integrating other Mac apps into Indigo, I HIGHLY recommend learning Python. It's easy to learn, there are tons of tutorials, and the syntax is not nearly as random as AppleScript.
Users browsing this forum: No registered users and 30 guests
