Exception in v0.4.4
Sat Apr 30, 2016 11:06 am
gazally offline
Exception in v0.4.4
My Honeywell account has 3 locations and 4 wifi thermostats, 2 of which are currently off-line until I can get to our vacation house and troubleshoot the DSL modem there. I have devices set up for the two which are online and I'm getting this error when I try to use the thermostat controls at the bottom of the Indigo home window:
  Honeywell                       [Maupin]: Setting HVAC Mode to: Heat
  Honeywell Error                 Error in plugin execution ExecuteAction:
  File "plugin.py", line 80, in actionControlThermostat
  File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Honeywell.IndigoPlugin/Contents/Server Plugin/Honeywell.py", line 942, in actionControlThermostat
<type 'exceptions.KeyError'>: (1667172735,)
Mon May 02, 2016 9:53 am
nlagaros offline
Re: Exception in v0.4.4
I'm thinking that you created the device after starting the plugin? If that is the case, I have a little bit of re-working to do in order to avoid this error.
Would you restart the plugin, and try changing the mode again? Thanks.
Tue May 03, 2016 7:19 am
gazally offline
Restarting the plugin fixed the problem. Thanks!
Sat May 07, 2016 3:06 am
Mirko offline
Indigo is running on my MacMiniServer 10.6.8
I have updated the Honeywell plug-in 0.4.4
I get all the time:
Stopping plugin "Honeywell 0.4.4". This may take a few seconds.
in the Log:
Error: Cannot authenticate to TCC Web API. Restarting in 30........
What is going wrong?
Regards Mirko
miniserver 2.jpg (25.71 KiB) Viewed 3515 times
Sun Jun 12, 2016 3:15 pm
Nick,
I just updated to 0.4.4. - and now getting these errors as well.
Attached my log showing all Honeywell activity since I updated tonight.
EDIT: Now added Debug log, which I enabled after I posted.
Peter
Honeywell_Debug.log
(14.73 KiB) Downloaded 182 times
Honeywell.log
(7.22 KiB) Downloaded 181 times
Tue Jul 12, 2016 7:22 pm
Ian offline
Just updated to 0.4.4 and gettimg some errors.
3 separate Devices set up.......All Honeywell Wi Fi Thermostats and all separate systems.
2 of the Systems are set for Heat Onlly.....Garage and Ians Home Heat.
Remaining System is AC only.
As you can see from the attachments....All 3 are actually working but missing some values......In the case of the 2 heat systems...They are missing values for cool setpoint as well as some others......and vice versa for the Cool system....missing heat setpoint and a few other values.
Any idea on how to rectify this?
Thanks in advance for the help
Screen Shot 2016-07-12 at 9.06.24 PM.png (102.39 KiB) Viewed 3372 times
Screen Shot 2016-07-12 at 9.04.27 PM.png (295.74 KiB) Viewed 3372 times
Sun Aug 07, 2016 6:15 am
nlagaros offline
Ian - this latest release is for you. Please give it a shot and let me know how it goes. I can't really test it as I do not have your model of thermostat. It may need a bit more of a tweak, but will leave it to you to let me know.
Thanks.
