Create Banner Image from Text Automator Workflow
Fri Apr 29, 2016 2:33 pm
Here's the details https://macosxautomation.com/automator/ ... index.html
This has huge potential for control pages. But dang if I can figure out how to do it except as a service accepting selected text. Obviously the ideal would be to have Indigo kick it off and have it grab text out of either a variable, or a written plain text file.
Any ideas?
Fri Apr 29, 2016 3:40 pm
Re: Create Banner Image from Text Automator Workflow
Create a workflow in Automator (after installing the component):
The script will pass the value of the variable to the "Create Banner Image from Text" component, which will then generate the image file. If you save that as an app from the Automator app, then you can create a trigger that fires whenever the variable changes with an "Open File" action. That will cause the image to be regenerated whenever the variable value changes.
Then you can use the image on a control page using the Refreshing URL image page element with "file://path/to/your/file.png" as the URL.
Fri Apr 29, 2016 4:00 pm
Nice find, BTW. You can use this to show multi-line text on control pages. Just insert the multi-line text into an Indigo variable (that works fine) and then have this workflow generate an image for it. Cool!
Sat Apr 30, 2016 8:08 am
Awesome! Thanks for the missing part I needed. Figured there was a way to put an applescript at the start of it, but I discovered this at the end of the work day and didn't have a chance to poke at it.
And to be clear for others reading this who may be new: this facility is built in to every modern Mac! The Create Banner Image from Text workflow is already on your computer in Automator.
I see lots of other potential workflows as well.
Sat Apr 30, 2016 11:31 am
messing with this a bit, and one thing:
Tried saving this as an app as suggested, and it gets an unknown error when it runs. As a workflow it works.
Sat Apr 30, 2016 1:47 pm
Pretty cool find. The one thing that I don't see is a way to set the output image dimensions. Since the image dimensions would routinely change (probably), loading the image into a control page as a refreshing image URL wouldn't be possible because it would probably wind up distorted.
I'd recommend saving the image to the static images folder of the Indigo web server -- then Indigo would be able to handle the changing image size and it would look normal.
At least I'm pretty sure it would. :D
Sat Apr 30, 2016 2:28 pm
I'll have to generate a bunch of different banners and see if there's a default size coded in.
Sat Apr 30, 2016 5:30 pm
Running as an app works for me.
Sat Apr 30, 2016 6:53 pm
I'll try the app again.
The size of the banner varies based on the text. and it puts all the text on one line, so this may not actually be such a great fix for breaking lines or fitting text.
Unless someone knows a way to encode line breaks so the banner will honor them.
Sat Apr 30, 2016 7:20 pm
When I typed an Option-Return, it honored the line break. So I suspect that a '\n' in a string would also be honored.
Users browsing this forum: No registered users and 17 guests
