RFXCOM detects Door Bell Press - How to trap it?
Mon Apr 04, 2016 7:39 am
Busta999 offline
I have ALL logging on the RFXCOM running.
Whenever my door bell is pressed I see:-
processing: 6 3 1 5 14 81 84 (06 03 01 05 0E 51 54)
In the Log for Indigo.
How can I trap this event and record it as a Door Bell press, hopefully to then cause the Hue lights to Flash.
Any insight
Tue Apr 05, 2016 1:11 am
b_weijenberg offline
Re: RFXCOM detects Door Bell Press - How to trap it?
This is an undecoded message and cannot be used.
This appears if undec on is enabled and a part of the RF message is displayed.
"undec on" should not be enabled in normal use to avoid receive of unusable messages.
Tue Apr 05, 2016 1:17 am
Busta999 offline
Ok what a pity.
Wed Apr 06, 2016 2:22 pm
colinpartridge offline
You could always change your door bell. Certain Byron models are supported, or use a Fibaro universal sensor. I use a Byron wireless door bell to trigger an announcement on a Sonos unit.
Colin
Wed Apr 06, 2016 2:53 pm
Busta999 offline
Yeh
I'll look into that.
It was a bonus seeing my Byron doorbell show and a long shot I could detect it.
Thu Apr 07, 2016 1:13 am
FYI the Byron I have is a SX14 model, but any sx compatible should work as I understand.
Colin
Fri Apr 08, 2016 5:29 am
Busta999 offline
I can see Byron56C Wireless Wall Mounted Door Bell for £11.56
That is both a Bell press and a bell.
Reckon that would work?
Mike
Fri Apr 08, 2016 6:11 am
I don't think so, the only ones mentioned in the rfxcom manual that are supported are the Byron SX range, It also has HomeEasy listed as well.
Colin
Fri Apr 08, 2016 6:50 am
Busta999 offline
Sorry
It is the Byron SX 56C
My mistake of omission :-)
Fri Apr 08, 2016 7:18 am
You should be in luck then, worth a shot at that sort of price. One thing I have noticed is the doorbell address does occasionally change, which is a pain, but you might have a different experience.
Colin
Mon Apr 18, 2016 10:37 am
Busta999 offline
OK The Byron SX 56C, well two of them, have arrived.
Confirmed it is a supported Byron SX doorbell.
When I press the doorbell i get
RFXCOM Debug processing: 8 80 7 5 64 0 2 4 121 (08 50 07 05 40 00 02 04 79)
How do I trap this as a Doorbell so I can automate other tasks off it?
Anyone any ideas, I haven't connected a doorbell before.
I have turned on the Byron channel for RFXCOM, in fact turned everything on to see if I get a different result.
I can't see Byron in the options for a RFXCOM device the drop down list. Closest I can get is a HomeEasy appliance (same company?)
Mon Apr 18, 2016 12:32 pm
You should see a doorbell device in the drop down menu.
C
RFX dropdown.png (115.99 KiB) Viewed 3994 times
Mon Apr 18, 2016 12:34 pm
Busta999 offline
C
Thanks Colin, as soon as I added the new RFXCOM plugin from the link you posted, it all worked.
PERFECT many thanks
Mon Apr 18, 2016 12:53 pm
Glad you got it working.. Have fun.
Colin
