How to fix "The data couldn't be read because..." error
Thu Dec 17, 2015 3:29 am
Gary_BBGames offline
Home Remote 2.9 is out now, but some of you might experience an error that says "The data couldn't be read because it isn't in the correct format" after trying to connect to your Indigo server.
There is an issue with the Indigo Mac app that allows you to paste carriage returns and tabs into a device or action name, the results of which is illegal JSON that cannot be parsed by iOS.
I do some string manipulation to fix it, but some combinations will slip through - especially tabs, which will be fixed in the next update.
You can resolve the issue yourself by going to http://indigoIP:indigoPort/devices.json in your browser and copying the results you see there in to the site http://jsonlint.com.
Once your data is there, press "Validate" and see if the JSON is valid. If it finds an error it will tell you the name of the action that is causing problems. Search the data for it and then fix the name in the Indigo Mac app. Try to reconnect to Indigo in Home Remote for iOS and it should work.
It might say that your devices.json file is fine, in which case the issue is with http://indigoIP:indigoPort/actions.json. Repeat the above steps with the contents of this file instead to resolve the issue.
Tue Feb 23, 2016 4:53 am
Re: How to fix "The data couldn't be read because..." error
HI Gary - I may have found another way to generate this error--having double-qotes in the Indigo notes field.
When the notes field contains double-quotes, the Indigo JSON doesn't throw any errors on JSON Lint, but I do get the "Data couldn't be read error" on Home Remote. Removing the double-quotes clears the error notification. Also, this may be expected, but with the "Data couldn't be read error" (double-quotes in the notes field) I don't get confirmation that the action has run on the Today Screen. When I take the double-quotes out of the notes field, I do get confirmation. I can reproduce this behavior.
This causes the error to throw:
Up before "Good Morning" schedule.
This doesn't:
Up before Good Morning schedule.
Cheers!
Dave
Tue Feb 23, 2016 5:03 am
Argh! If possible could you let Jay or Matt know they are generating illegal JSON their side when they allow this please? They should be escaping any values like that. I'll try and add a check, but not sure I will be able to as the " is used all over the place.
Tue Feb 23, 2016 6:28 am
Can do!
Dave
Tue Feb 23, 2016 10:44 am
Sigh. We hacked the JSON stuff in a couple of years ago and didn't really do a thorough job of it. I was hoping my last hack on hack fix would keep us from having to do the real fix until we moved IWS into a true plugin.
I'll look to see if there's any way to a faster solution for this particular problem.
Tue Feb 23, 2016 5:21 pm
Ok, I just bit the bullet and replaced the JSON generation in the RESTful API with Python's json module. So after the next release, any bugs in the json generation can get blamed on Python!
Tue Feb 23, 2016 7:01 pm
Thanks Jay!
Wed Feb 24, 2016 5:02 am
Jay, thanks so much for that. Will be interesting to see what the results are :)
