Qubino dual relay module
Fri Oct 30, 2015 4:52 pm
colinpartridge offline
I have just installed one of the Qubino dual relay power switches. works well except that turning relay 2 in Indigo switches both relays on, not the expected result. Parameter 10 in the unit is set to 0 which I thought should eliminate any combined switching.. Switching relay 1 appears to work as expected. Anyone have experience of this or ideas why it might be happening. heres the zwave debug log for switching on relay 2 if it helps..
Z-Wave Debug                    SENT setRelayValue: 01 0E 00 13 4B 07 60 0D 01 02 25 01 FF 05 82 9C
 Z-Wave                          sent "075 - Cabin Lights" on
 Z-Wave Debug                    queueing request of "075 - Cabin Verandah " (activity detected)
 Z-Wave Debug                    RCVD requestRelayStatus: 01 09 00 04 00 4B 03 25 03 FF 63
 Z-Wave Debug                    . .  requestRelayStatus: node 075, endpoint None, value 255
 Z-Wave                          received "075 - Cabin Verandah " status update is on
 Z-Wave Debug                    RCVD requestMeterLevel: 01 10 00 04 00 4B 0A 32 02 21 34 00 00 00 D7 00 00 58
 Z-Wave Debug                    . .  requestMeterLevel: node 075, endpoint None, meterType 01, raw value 3400...
 Z-Wave Debug                    . .  requestMeterLevel: 21.5 W (float: 21.500000)
 Z-Wave                          received "075 - Cabin Verandah " power load to 21.5 W
 Z-Wave Debug                    polling status of node "075 - Cabin Verandah " (post-activity list)
 Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 4B 03 32 01 00 05 83 1B
 Z-Wave Debug                    RCVD requestMeterLevel: 01 14 00 04 00 4B 0E 32 02 21 24 00 00 00 00 00 01 00 00 00 00 9E
 Z-Wave Debug                    . .  requestMeterLevel: node 075, endpoint None, meterType 01, raw value 2400...
 Z-Wave Debug                    . .  requestMeterLevel: 0.0 kWh (float: 0.000000)
 Z-Wave Debug                    SENT requestMeterLevel: 01 0A 00 13 4B 03 32 01 10 05 84 0C
 Z-Wave Debug                    RCVD requestMeterLevel: 01 10 00 04 00 4B 0A 32 02 21 34 00 00 00 DA 00 00 55 (unsolicited3 -- requeuing)
 Z-Wave Debug                    . .  requestMeterLevel: 21.8 W (float: 21.800000)
 Z-Wave                          received "075 - Cabin Verandah " power load to 21.8 W
 Z-Wave Debug                    RCVD requestMeterLevel: 01 10 00 04 00 4B 0A 32 02 21 34 00 00 00 DB 00 00 54
 Z-Wave Debug                    . .  requestMeterLevel: 21.9 W (float: 21.900000)
 Z-Wave                          received "075 - Cabin Verandah " power load to 21.9 W
Colin
Sat Oct 31, 2015 1:07 pm
Ksullivan offline
Re: Qubino dual relay module
Hi Colin
These relays are not yet fully supported but should be in the next release fingers crossed
Sun Nov 01, 2015 4:57 am
I thought that might be the case, just wanted to make sure I hadn't missed a trick.
Colin
Thu Dec 24, 2015 2:57 am
SgtBilko offline
Oh no !!!!!
I really must do more research before I buy stuff.
I bought a number of these as they are the only gen5 products I could find to suit what I needed to do...... reach a double relay about 30m from my house.
They work a treat and I now get a rock solid connection.
Only problem is now that my trees lights come on when I start the pond pump up !!
Early support from the Indigo team would be much appreciated here !!
Ian
Sun Jan 10, 2016 11:50 am
SgtBilko offline
Any update, please ?
Sun Jan 10, 2016 11:53 am
We aren't providing individual updates or time estimates for hardware support, but we are actively working on lots of new Z-Wave support for an upcoming major release. Sorry we cannot be more specific.
Sun Jan 17, 2016 12:41 am
SgtBilko offline
Thank you Matt
Sun Jan 17, 2016 4:48 am
haavarda offline
A little of topic, but anyway. Matt is there going to be a beta testing round for indigo 7? Or will it just be there some day?
Håvard
Sun Jan 17, 2016 9:10 am
We haven't decided how we're handling the beta for Indigo 7 yet. We'll note your interest. ;)
Sun Jan 17, 2016 9:12 am
The last beta for IT2/6.1 worked well I thought.
That's assuming I was in it, which I might or might not have been. ;-)
Sun Jan 17, 2016 10:06 am
durosity offline
Sign me up for alpha testing... My wife would *so* love that
Sun Jan 17, 2016 10:33 am
haavarda offline
or I don't know the difference! But yes Jay I am up for any type of testing
Håvard
Sun Nov 13, 2016 2:24 pm
Ksullivan offline
Hi Matt / Jay
Still have the same issue with Indigo 7 when relay 2 turns on both Relay 1 and 2 turn on :(
Any ideas
Sun Nov 13, 2016 2:29 pm
durosity offline
Weird, I was literally about to post that myself! I concur, turning on relay 2 causes 1 to also switch to on. Also turns off 1 if 2 is turned off. Not tested locally as the one i have enabled doesn't have any local controls :)
Sun Nov 13, 2016 2:52 pm
jens offline
Try to re synk the Qubino again it helped for me.
