Weathersnoop communication broken with 6.1.3
Wed Aug 19, 2015 6:15 am
RonA offline
New error blocking communication with Weathersnoop 3.3.1.1 since upgrade to Indigo 6.1.3. I have two devices setup for two different weather sources.
WeatherSnoop Debug Updating device: OS Weather Underground iLouthDU2
WeatherSnoop Error Couldn't get site information from WeatherSnoop for device "OS Weather Underground iLouthDU2" - check to see if WeatherSnoop is running correctly.
WeatherSnoop Debug Error specifics:
File "plugin.py", line 528, in update
self.updateWs3DeviceState(device, valueDict, "value", valueDict["type"], stateKey, uiVal)
File "plugin.py", line 680, in updateWs3DeviceState
device.updateStateOnServer(key=propKey, value=newValue, decimalPlaces=places, uiValue="%s%s" % (unicode(newValue), uiVal))
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc2 in position 1: ordinal not in range(128)
WeatherSnoop Debug Updating device: OS Weather Wise Solar Pro
WeatherSnoop Error Couldn't get site information from WeatherSnoop for device "OS Weather Wise Solar Pro" - check to see if WeatherSnoop is running correctly.
Wed Aug 19, 2015 6:49 am
wmcorbin offline
Re: Weathersnoop communication broken with 6.1.3
I updated to 6.1.3 and WeatherSnoop is now reporting an error of -> Couldn't get site information from WeatherSnoop for device "then name of the device."
I reverted back to 6.1.2 however the error is still there.
Wed Aug 19, 2015 6:52 am
jens offline
Same for me
Sent from my iPhone 6 using Tapatalk
Wed Aug 19, 2015 7:41 am
Send an email to support@indigodomo.com with a link to this thread and I'll get a patch to you to test when I have one available.
Sat Aug 22, 2015 10:45 am
jens offline
But it worked for a while, then got this error message
:roll:
22 aug 2015 18:43:34
Reloading plugin "WeatherSnoop 2.0.7"
Stopping plugin "WeatherSnoop 2.0.7" (pid 34294)
WeatherSnoop Debug Received StopThread - shutting down the dns browser
WeatherSnoop Debug Stopping device: new device
Stopped plugin "WeatherSnoop 2.0.7"
Starting plugin "WeatherSnoop 2.0.7" (pid 70169)
Started plugin "WeatherSnoop 2.0.7"
WeatherSnoop Debug Starting device: new device
WeatherSnoop Debug Updating device: new device
WeatherSnoop Debug Getting weather.xml
WeatherSnoop Debug Got weather.xml
WeatherSnoop Error exception in deviceStartComm(new device): no element found: line 1, column 0
WeatherSnoop Debug Starting concurrent tread
WeatherSnoop Debug __adding to queue
WeatherSnoop Debug command: ('add', u'CJ-DiskStation(WebDAV)', u'CJ-DiskStation.local.', 5005)
WeatherSnoop Debug command: ('add', u'CJ-DiskStation', u'CJ-DiskStation.local.', 5000)
WeatherSnoop Debug command: ('add', u'HIKVISION DS-2CD2532F-IWS - 501678738', u'DS-2CD2532F-IWS20150125CCCH501678738.local.', 80)
WeatherSnoop Debug command: ('add', u'SecuritySpy', u'Minis-Mac-mini.local.', 7000)
WeatherSnoop Debug command: ('add', u'Canon MF8200C Series', u'Canon510e49.local.', 80)
WeatherSnoop Debug command: ('add', u'Indigo - My House', u'Minis-Mac-mini.local.', 8176)
WeatherSnoop Debug command: ('add', u'WeatherSnoop 3', u'Minis-Mac-mini.local.', 8000)
WeatherSnoop Debug Server list: {u'WeatherSnoop 3@Minis-Mac-mini.local.:8000': u'Minis-Mac-mini.local.:8000'}
//Jens
Sat Aug 22, 2015 11:45 am
Looks like you tried to add a new device. Have you finished configuring that device (in the device's config dialog)?
Sat Aug 22, 2015 11:49 am
Actually, that's not the new 2.0.9 version of the plugin. Upgrade to Indigo 6 v6.1.4 that has the new plugin in it and see if the problem persists.
Sat Aug 22, 2015 3:56 pm
jens offline
Strange have don that
Sun Aug 23, 2015 10:09 am
I just ran the 6.1.4 installer on my production Mac (which I hadn't updated past 6.1.0) and I now have the 2.0.9 version of the WeatherSnoop plugin. Not sure what's going on with your install.
Mon Aug 24, 2015 1:59 am
jens offline
Now a have 2.0.9 :D But this error :|
Reloading plugin "WeatherSnoop 2.0.9"
Stopping plugin "WeatherSnoop 2.0.9" (pid 91009)
Stopped plugin "WeatherSnoop 2.0.9"
Starting plugin "WeatherSnoop 2.0.9" (pid 1816)
Started plugin "WeatherSnoop 2.0.9"
WeatherSnoop Debug command: ('add', u'WeatherSnoop 3', u'Minis-Mac-mini.local.', 9000)
WeatherSnoop Debug Server list: {u'WeatherSnoop 3@Minis-Mac-mini.local.:9000': u'Minis-Mac-mini.local.:9000'}
Mon Aug 24, 2015 8:23 am
So, are you trying to configure a new device, and if so is it configured properly? Try deleting it and starting over.
Tue Aug 25, 2015 2:24 pm
jens offline
Yes, trying to add new device, and deleting, but the same results... :|
Tue Aug 25, 2015 2:28 pm
jens offline
it´s the server when adding that this error came, have weathersnoop on same computer have tried localhost, 127.0.0.1, 192.168.0.168 and have port 9000 now have tried 8000 but same result
Tue Aug 25, 2015 3:33 pm
So, when it opens the "Configure WeatherSnoop 3 Agent" config dialog, what shows up in the Select WeatherSnoop instance popup? I'm unclear why you're entering IP addresses and port numbers...
Tue Aug 25, 2015 3:56 pm
jens offline
Weather snoop agent working but not when importing it to indingo
Skärmavbild 2015-08-24 kl. 09.56.04.jpg (29.84 KiB) Viewed 5699 times
