I had some difficulty with the script mentioned on this thread, it later turned out it was my mistake, as usual. However, in the meantime I dug around and found a Python script that does a much simpler job of controlling Wemo devices from Indigo. I am guessing a much more savvy user than myself can script it using the Indigo built in Python script editor but for me, I use the Do shell Script with Applescript.
- Code: Select all
do shell script "wemo switch \"Kitchen Light\" on"
turns on the kitchen light.
The project website is here as well as a link to the complete documentation
https://pypi.python.org/pypi/ouimeauxYou will need command line developer tools (don't need Xcode, simply type git in the terminal and you will be prompted to download the command line tools). Once installed, Wemo devices can be used easily! No need for IFTTT.
