Add hours to a timestamped variable
Fri Jun 10, 2022 4:32 pm
billorav offline
I can't find an easy way to add time (hours or minutes) to a time stamped variable. Once accomplished I would put that modified time into a new variable. I'm sure there is an easy way to accomplish this but I do not have any Python experience and couldn't find a plugin to do this. Any help would be appreciated.
Bill
Fri Jun 10, 2022 4:35 pm
Re: Add hours to a timestamped variable
It’s going to depend on the way the original time stamp was generated when placed in the variable. Can you post an example?
Fri Jun 10, 2022 8:13 pm
billorav offline
My string in the variable has truncated the seconds and leading year and looks something like this:
06-10 14:20
But I can make it the standard format in the timestamp variable if that makes it easier. I just wanted to add 4-6 hours onto an existing variable string to show up in a control panel. Like you need to do this in 4 hours at such and such time.
Thanks for looking at this so quickly.
Bill
Fri Jun 10, 2022 9:35 pm
How are you actually populating that variable? Script?
Sat Jun 11, 2022 9:48 am
billorav offline
I'm using the Modify Variable
Screen Shot 2022-06-11 at 8.45.29 AM.png (84.14 KiB) Viewed 5636 times
Sat Jun 11, 2022 9:58 am
This is pretty much all explained (except for the Indigo part) on this page: https://stackoverflow.com/questions/436 ... -timestamp
The Indigo part (reading and writing variables) is here: https://wiki.indigodomo.com/doku.php?id ... e_examples
The steps you need are:
  1. Read the Original variable into a Python string
  2. Use strptime to parse that string into a datetime object
  3. Use timedelta to add time to the datetime object
  4. Use strftime to generate a new string from the datetime object
  5. Save the new string to the new Indigo variable.
Sat Jun 11, 2022 2:44 pm
billorav offline
Well I was able to split the hours out but have become completely stumped beyond that. Can't get the 4 hours added to the hour string. I'm an infant when it comes to Python scripting. Not sure if there is an easier way to accomplish what I trying to do.
My wife is having surgery next week and needs to take pain meds every 4 hours. I created a control page that counts down the time and then starts over when you hit the start button again. Also logs the action. I thought it would be helpful if I could display the next time to take the next set of pills when she hits the start button. I also could use a variable to change the "4" to like a 6 for 6 hours).
I lot to ask, but I would be very grateful for any ideas to accomplish this.
Bill
Sat Jun 11, 2022 2:53 pm
Bill
Post what you have so far and we'll help you along.
Sat Jun 11, 2022 5:10 pm
billorav offline
I started with this:
Variable: vpilltaketime timestamp 06-10 14:20
Format in insert Timestamp into Variable: %m-%d %H:%M
Then stared with this Python Script:
firstpill = indigo.variables["vpilltaketime"].value
indigo.variable.updateValue("vpillnexttime", firstpill[6:8])
Didn't get much further since my script wouldn't compile when used the strptime (more likely incorrectly.
Sat Jun 11, 2022 6:17 pm
Use the "Code" tags, not Bold.
import indigo
from datetime import datetime, timedelta
DATEFORMAT = '%m-%d %H:%M'
# step 1
# step 2
timestamp = datetime.strptime(firstpill, DATEFORMAT)
# step 3
timestamp = timestamp + timedelta(hours=4)
# step 4
nextpill = timestamp.strftime(DATEFORMAT)
# step 5
indigo.variable.updateValue("vpillnexttime", nextpill)
Sat Jun 11, 2022 8:17 pm
billorav offline
Your script works fantastic the first time!
I wish I could exchange the favor.
I do use Ecobee 2 extensively with 4 stats. If I see anything to debug as time goes by I'll let you know.
If I had more time, I would play around with Python.
Thanks again!
Bill
Sat Jun 11, 2022 10:31 pm
billorav offline
I hate to bother you one more time, but I have tried to change the "4" hour in step 3 to a variable but I get the unicode error. Tried to update the value of the variable to an integer with no luck. I'm sure its simple but you are dealing with a python dummy here.
# step 3
I would like to change the 4 to a variable and the add to the timestamp
My wife will thank you also after a painful shoulder surgery is coming up next week and we need to track the pain meds. Here is a start of my control page:
Bill
Sun Jun 12, 2022 2:30 am
Bill
Have you played with the Timers & Pesters plugin, or Timed Devices plugin?
Both I’m sure will help you achieve this in native timed formats rather than trying to parse and increment strings.
Sun Jun 12, 2022 5:54 am
import indigo
# step 1
# step 2
# step 2.5 - get the time interval
vpilldelay = indigo.variables["vpilldelay"].value
# step 3
timestamp = timestamp + timedelta(hours=int(vpilldelay))
# step 4
# step 5
Sun Jun 12, 2022 10:02 am
billorav offline
Thank you. We're all set now.
