Survive a reboot
Fri Oct 04, 2019 9:41 am
lalisingh offline
Survive a reboot
Forgive me if this has been answered.
How fo you have a timer state survive a reboot.
[url]https://www.VillageWorker.com[/url]
Extreme data analytics, Sensing, Control integration work.
Indigo • Barix • Kentix • Mobotix • Mikrotik • Apple
Sun Oct 06, 2019 11:27 am
Re: Survive a reboot
I don't believe there is a good/simple solution to this. Currently upon server startup all device Timers are reset to the inactive state. I'll talk to Jay and we'll consider adding a device level property, like "Preserve timer status across restarts", that let's the user specify at the device level what behavior they want.
Sun Oct 06, 2019 1:50 pm
lalisingh offline
Thanks Matt,
Managing occupancy triggers is my crtical use case for timers. Having the timers survive a power flicker is important.
Workaaround is using variables ofcourse.
Sun Oct 06, 2019 3:43 pm
FlyingDiver online
lalisingh wrote:
Thanks Matt,
A better workaround is to put the Indigo server on a UPS.
Sun Oct 06, 2019 5:06 pm
In pibeacon plugin nothing gets set to off in the first 90 seconds after start of plugin.
That should cover any restart reboot timing issues.
Sun Mar 19, 2023 5:37 am
Vaillant offline
Has this ever been resolved?
On restart Timers are reset to the inactive state.
This triggers a few actions for me.
Problem is that the external plugins are not loaded yet so I get errors.
I prevent the errors using Event Timer Expired in my triggers.
However I do somehow want to trigger my actions when the external plugins are loaded and set to inactive.
So: Timer Test Active > Restart > Trigger Timer Test > Execute Action External Plugin
Adrian
Sun Mar 19, 2023 11:22 am
We haven't done any work on this. TBH, the priority is quite low compared to many other things.
