[SOLVED]setting start value to variable value
Sat Apr 04, 2015 6:38 am
haavarda offline
As the topic implies I am trying to set a timer start value to the value of a variable. Like a count down clock.
I have tried the following phyton script, but it fails. Any suggestions?
verdi = indigo.variables[1201785696] # "Nedtellingstimer"
tId = "com.perceptiveautomation.indigoplugin.timersandpesters"
timerPlugin = indigo.server.getPlugin(tId)
if timerPlugin.isEnabled():
timerPlugin.executeAction("setTimerStartValue", deviceId=238449231, props={'amount':'verdi', 'amountType':'minutes'})
Timers and Pesters Error Set Timer action failed validation
Håvard
Håvard
Sat Apr 04, 2015 7:00 am
Re: setting start value to variable value
Instant response without double checking but try removing the quotes around verdi i.e.:
timerPlugin.executeAction("setTimerStartValue", deviceId=238449231, props={'amount':verdi, 'amountType':'minutes'})
Putting the quotes around it, turns it into a string with a value 'verdi' whereas you want to access the variable verdi (with no quotes). :)
Sat Apr 04, 2015 7:03 am
Also, just spotted this, the statement:
should be
verdi = indigo.variables[1201785696].value # "Nedtellingstimer"
You need to specify the '.value' to get at the value of the variable.
Sat Apr 04, 2015 9:26 am
haavarda offline
Thank you. That worked perfectly.
I now have a variable that when updated starts a timer with the value that was entered. When the timer expires a sonos announcement is played.
In other words, a fancy kitchen timer :)
   timerPlugin.executeAction("restartTimer", deviceId= 238449231)
Håvard
Håvard
