SQL Logger Error Error in plugin execution startup:
Fri Oct 13, 2017 1:37 pm
siclark offline
Matt. Jay
What have I done? I keep getting this error at startup, and every 10 seconds on the sql logger .
Tried disabling all 3rd party plugins and stopping server, quitting Indigo and restarting.
This is the error Message I get on startup
Enabling plugin "SQL Logger 2.0.5"
Starting plugin "SQL Logger 2.0.5" (pid 1649)
Started plugin "SQL Logger 2.0.5"
File "plugin.py", line 600, in startup
File "plugin.py", line 473, in _connectToSqlDb
ValueError: invalid literal for int() with base 10: ''
SQL Logger Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 610, in runConcurrentThread
SQL Logger Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
I am confused though as I dont even see a plugin.py file in the SQL logger plugin package. The python files there either dont have a line 473 or 610, or dont have anything that could indicate that sort of error, in my basic python understanding.
I have .py and .pyc in the indigologger folder, is that right? They arent there on a clean install .
Fri Oct 13, 2017 3:55 pm
Re: SQL Logger Error Error in plugin execution startup:
It looks like maybe the configuration file has become corrupt. Try stopping the plugin, then delete this file (and restart the plugin):
/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/com.perceptiveautomation.indigoplugin.sql-logger.indiPref
Sat Oct 14, 2017 5:37 am
siclark offline
Amazing.. That did it. thanks for the quick response. I moved this to a new thread to make it more clear for others with the same error message.
