postgresql.org or postgresapp.com
Thu Oct 12, 2017 9:09 am
siclark offline
Pretty much as the title says. Can I use either or, and are there any advantages / disadvantages to either?
Thu Oct 12, 2017 10:15 am
RogueProeliator offline
Re: postgresql.org or postgresapp.com
I have used both with SQL Logger and both work equally well. However, the App version is about 10,000x easier to setup.... I believe that it requires that it run in User space, but since Indigo doesn't run as a daemon, no problem there. In short, go with the application version if you want to save yourself some headaches!
Adam
Thu Oct 12, 2017 10:18 am
siclark offline
Perfect, thanks
